Installation & Licensing
3DS Max 2012, STILL won't install despite work arounds
4 REPLIES 4
398 Views, 4 Replies
So, I have tried the work-arounds proposed by the professionals here on the site. I have remove prerequisites and made sure errors were ignored. I'm starting to lose faith in Autodesk. I am astonished they made a product that will not instal properly that costs quite a bit of money. I'm glad mine is only the educational version.
Installation Log:
2014/5/8:19:03:58    SPEKTRE    SPEKTRE-PC    === Setup ended ===
2014/5/8:19:02:06    SPEKTRE    SPEKTRE-PC    === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:02:06    SPEKTRE    SPEKTRE-PC    Launch
2014/5/8:19:04:00    SPEKTRE    SPEKTRE-PC    PageOpen    LaunchDialog
2014/5/8:19:04:22    SPEKTRE    SPEKTRE-PC    PageOpen    LicenseDialog
2014/5/8:19:04:27    SPEKTRE    SPEKTRE-PC    PageOpen    ProductInfoDialog
2014/5/8:19:04:48    SPEKTRE    SPEKTRE-PC    PageOpen    ProductSelectionDialog2
2014/5/8:19:04:51    SPEKTRE    SPEKTRE-PC    PageOpen    FullProgressDialog
2014/5/8:19:04:52    SPEKTRE    SPEKTRE-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\SPEKTRE\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/8:19:05:15    SPEKTRE    SPEKTRE-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2014/5/8:19:05:15    SPEKTRE    SPEKTRE-PC    PageOpen    InstallCompleteDialog
2014/5/8:19:12:35    SPEKTRE    SPEKTRE-PC    === Setup ended ===
2014/5/8:19:24:34    SPEKTRE    SPEKTRE-PC    === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:24:34    SPEKTRE    SPEKTRE-PC    Launch
2014/5/8:19:24:46    SPEKTRE    SPEKTRE-PC    === Setup ended ===
2014/5/8:19:32:24    SPEKTRE    SPEKTRE-PC    === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:32:24    SPEKTRE    SPEKTRE-PC    Launch
2014/5/8:19:32:40    SPEKTRE    SPEKTRE-PC    === Setup ended ===
2014/5/8:19:32:25    SPEKTRE    SPEKTRE-PC    === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:32:25    SPEKTRE    SPEKTRE-PC    Launch
2014/5/8:19:32:40    SPEKTRE    SPEKTRE-PC    PageOpen    LaunchDialog
2014/5/8:19:32:57    SPEKTRE    SPEKTRE-PC    PageOpen    LicenseDialog
2014/5/8:19:33:00    SPEKTRE    SPEKTRE-PC    PageOpen    ProductInfoDialog
2014/5/8:19:33:18    SPEKTRE    SPEKTRE-PC    PageOpen    ProductSelectionDialog2
2014/5/8:19:33:38    SPEKTRE    SPEKTRE-PC    PageOpen    FullProgressDialog
2014/5/8:19:33:38    SPEKTRE    SPEKTRE-PC    Installing .NET Framework Runtime 4.0: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2014/5/8:19:34:01    SPEKTRE    SPEKTRE-PC    Install    .NET Framework Runtime 4.0    Failed    Failure is ignored, Result=1603
2014/5/8:19:34:01    SPEKTRE    SPEKTRE-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/5/8:19:36:12    SPEKTRE    SPEKTRE-PC    Install    DirectX® Runtime    Succeeded
2014/5/8:19:36:12    SPEKTRE    SPEKTRE-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2014/5/8:19:36:15    SPEKTRE    SPEKTRE-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2014/5/8:19:36:15    SPEKTRE    SPEKTRE-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/5/8:19:36:34    SPEKTRE    SPEKTRE-PC    Install    Autodesk Material Library 2012    Succeeded
2014/5/8:19:36:34    SPEKTRE    SPEKTRE-PC    Installing Autodesk Material Library 2012 - Base Image Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/5/8:19:37:12    SPEKTRE    SPEKTRE-PC    Install    Autodesk Material Library 2012 - Base Image Library    Succeeded
2014/5/8:19:37:12    SPEKTRE    SPEKTRE-PC    Installing Autodesk Material Library 2012 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/5/8:19:38:39    SPEKTRE    SPEKTRE-PC    Install    Autodesk Material Library 2012 - Medium Resolution Library    Succeeded
2014/5/8:19:38:39    SPEKTRE    SPEKTRE-PC    Installing Autodesk® Backburner 2012: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\x86\Components\backburner\BackburnerCIF.exe
2014/5/8:19:38:54    SPEKTRE    SPEKTRE-PC    Install    Autodesk® Backburner 2012    Succeeded
2014/5/8:19:38:56    SPEKTRE    SPEKTRE-PC    Installing Autodesk® 3ds Max 2012:  TRANSFORMS="C:\Users\SPEKTRE\AppData\Local\Temp\_AI1229.tmp\x86\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/5/8:19:41:57    SPEKTRE    SPEKTRE-PC    Install    Autodesk® 3ds Max 2012    Failed    Installation aborted, Result=1603
2014/5/8:19:41:57    SPEKTRE    SPEKTRE-PC    Rollback    Autodesk® Backburner 2012    Failed    Installation aborted, Result=1619
2014/5/8:19:42:31    SPEKTRE    SPEKTRE-PC    Rollback    Autodesk Material Library 2012 - Medium Resolution Library    Succeeded
2014/5/8:19:42:50    SPEKTRE    SPEKTRE-PC    Rollback    Autodesk Material Library 2012 - Base Image Library    Succeeded
2014/5/8:19:43:25    SPEKTRE    SPEKTRE-PC    Rollback    Autodesk Material Library 2012    Succeeded
2014/5/8:19:43:25    SPEKTRE    SPEKTRE-PC    Rollback    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2014/5/8:19:43:25    SPEKTRE    SPEKTRE-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/5/8:19:43:26    SPEKTRE    SPEKTRE-PC    PageOpen    InstallCompleteDialog
2014/5/8:19:44:06    SPEKTRE    SPEKTRE-PC    === Setup ended ===
2014/5/8:19:47:44    SPEKTRE    SPEKTRE-PC    === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:47:44    SPEKTRE    SPEKTRE-PC    Launch
2014/5/8:19:48:03    SPEKTRE    SPEKTRE-PC    === Setup ended ===
2014/5/8:19:47:45    SPEKTRE    SPEKTRE-PC    === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:47:45    SPEKTRE    SPEKTRE-PC    Launch
2014/5/8:19:48:03    SPEKTRE    SPEKTRE-PC    PageOpen    LaunchDialog
2014/5/8:19:48:19    SPEKTRE    SPEKTRE-PC    PageOpen    LicenseDialog
2014/5/8:19:48:22    SPEKTRE    SPEKTRE-PC    PageOpen    ProductInfoDialog
2014/5/8:19:48:44    SPEKTRE    SPEKTRE-PC    PageOpen    ProductSelectionDialog2
2014/5/8:19:48:46    SPEKTRE    SPEKTRE-PC    PageOpen    FullProgressDialog
2014/5/8:19:48:46    SPEKTRE    SPEKTRE-PC    Installing .NET Framework Runtime 4.0: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2014/5/8:19:49:02    SPEKTRE    SPEKTRE-PC    Install    .NET Framework Runtime 4.0    Failed    Failure is ignored, Result=1603
2014/5/8:19:49:02    SPEKTRE    SPEKTRE-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/5/8:19:49:15    SPEKTRE    SPEKTRE-PC    Install    Autodesk Material Library 2012    Succeeded
2014/5/8:19:49:15    SPEKTRE    SPEKTRE-PC    Installing Autodesk Material Library 2012 - Base Image Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/5/8:19:49:39    SPEKTRE    SPEKTRE-PC    Install    Autodesk Material Library 2012 - Base Image Library    Succeeded
2014/5/8:19:49:39    SPEKTRE    SPEKTRE-PC    Installing Autodesk Material Library 2012 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/5/8:19:50:28    SPEKTRE    SPEKTRE-PC    Install    Autodesk Material Library 2012 - Medium Resolution Library    Succeeded
2014/5/8:19:50:28    SPEKTRE    SPEKTRE-PC    Installing Autodesk® Backburner 2012: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\x86\Components\backburner\BackburnerCIF.exe
2014/5/8:19:50:28    SPEKTRE    SPEKTRE-PC    Install    Autodesk® Backburner 2012    Succeeded
2014/5/8:19:50:28    SPEKTRE    SPEKTRE-PC    Installing Autodesk® 3ds Max 2012:  TRANSFORMS="C:\Users\SPEKTRE\AppData\Local\Temp\_AI1B3E.tmp\x86\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/5/8:19:59:05    SPEKTRE    SPEKTRE-PC    Install    Autodesk® 3ds Max 2012    Failed    Installation aborted, Result=1603
2014/5/8:19:59:05    SPEKTRE    SPEKTRE-PC    Rollback    Autodesk® Backburner 2012    Failed    Installation aborted, Result=1619
2014/5/8:19:59:30    SPEKTRE    SPEKTRE-PC    Rollback    Autodesk Material Library 2012 - Medium Resolution Library    Succeeded
2014/5/8:19:59:49    SPEKTRE    SPEKTRE-PC    Rollback    Autodesk Material Library 2012 - Base Image Library    Succeeded
2014/5/8:20:00:20    SPEKTRE    SPEKTRE-PC    Rollback    Autodesk Material Library 2012    Succeeded
I now have a 'NEW' error for you to look at. Please see the attached screen capture image.
Tags (2)
4 REPLIES 4
TravisNave
Disable your antivirus and make sure you have admin rights on your machine.
Also, do NOT install with a service pack.  Choose not to:
http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2013-Suite-failed-installation-aborted-...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dgorsman
Not immediately obvious to me - what are your system specs and OS version?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
in reply to: TravisNave
Thank you sir I will try that Smiley Happy
There is no option to deselect a service pack however I am not running my Anti-Virus and I am installing now 'Run as Admin'.
Administrator Productivity
