Installation & Licensing
3ds max 2012 on a removable HDD - can't remove registry info
5 REPLIES 5
2743 Views, 5 Replies
I installed 3ds max earlier on a portable hard drive.
Now that the disk was reformatted and the software executables are gone.
When I try to uninstall from the windows "remove programs" window, the uninstaller cannot be run.
So tried to remove its traces by deleting "Autodesk" related stuff in registry and %APPDATA%.
And when I run the installer again it tells me 3ds max 2012 is installed. But it is really NOT installed.
How do I cleanup a 3ds max installation? Please help! I don't want to have to reinstall my system.
5 REPLIES 5
nicodeneef
in reply to: nicodeneef
Thanks for the response!
Here is what I did:
Run every uninstaller in "Add or Remove Programs"
Deleted every "autodesk" folder in Program Files, Program Files (x86), Common Files, APPDATA.
Deleted Autodesk registry in software and even in Wow6432Node in both CURRENT_USER and LOCAL_MACHINE.
I rerun the installer, it still tells me that 3ds max is installed...wierd.
TravisNave
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
You should take extreme caution when using the MSICUU2 file in Windows 7 as it can result in a 1402 error on subsequent installs.  That problem can be fixed in the registry as well.  Please read my entire post on this issue carefully.  It is recommended that you try the clean uninstall process listed by Autodesk first.
Autodesk Forums:
in reply to: TravisNave
Thank you
So the Microsoft Installer Cleaner Utility worked. I was just unable to obtain one copy.
I have the same problem here. Is still tell me that the 3dsmax 2012 is installed when i already did unistall and delete all the register from regedit.
I tryed the Microsoft Installer Cleaner Utility but  0 result. it didn't found nothing about the 3ds max 2012.
What should i do? i don't want to use the 2013 version, because a lot of scripts and plug-in will dont work.
The only chance is to reinstall the system.. but i don't want.
Thanks!
Administrator Productivity
