Installation & Licensing
Member
Comanderblack
Message 1 of 8 (3,477 Views)
3DS Max 2012 fails to install
3477 Views, 7 Replies
05-16-2011 01:16 AM
Hi. I try to install this program a lot of times and always fails. I tried first normally, and then in Safe Mode and I always get errors. I don't know what to do now...
In the log file i have deleted some installations with the same error.
TravisNave
Message 2 of 8 (3,461 Views)
Re: 3DS Max 2012 fails to install
05-16-2011 07:55 AM in reply to: Comanderblack
You'll need to attach the bigger installation log in your %temp% location.  It will have more information that can help locate the problem.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
Comanderblack
Message 3 of 8 (3,458 Views)
05-16-2011 08:10 AM in reply to: TravisNave
Can you tell me the name of this .log files? I have a lot of them...
Edit: I think i have found it.
Note: My OS Language is spanish
Member
Comanderblack
Message 4 of 8 (3,368 Views)
05-28-2011 05:06 AM in reply to: Comanderblack
Nobody can help me? I don't know what to do...
Member
emi_100
Message 5 of 8 (3,346 Views)
05-29-2011 08:41 AM in reply to: Comanderblack
I think all problems are becouse of a deficient framework 4.
When i install it, all problems appeared. (i have to use a framework cleanup tool to delete it)
I donwload the full installer from the Microsoft site, but it's the same.
Framework 4 is the problem.
Member
Comanderblack
Message 6 of 8 (3,340 Views)
05-29-2011 01:32 PM in reply to: emi_100
Hi and thanks for reply.
I have unistalled all frameWork, but when I try to install, the 3DS Max Installer install FrameWork 4. And it fail again...
Member
emi_100
Message 7 of 8 (3,337 Views)
05-29-2011 01:37 PM in reply to: Comanderblack
I know, same thing happen with all the Autodesk Suite 2012 that use Framework 4.0.
My friend have Revit 2012, and the same problem.
But is not a problem of the Autodesk program, is a bug on the Framework 4.0.
I download it from Microsoft site, and it have the same problem... stil waiting for the hotfix...
Member
Comanderblack
Message 8 of 8 (3,183 Views)
06-24-2011 09:19 AM in reply to: emi_100
I have found a "solution" (I have installed it and it works). I have seen that it is a security problem. The installer can't write (i don't know) in the windows folders. To solve it I have Unhide and give right to everybody to "?:\Users\User Name\AppData". Doing this I can install
