I just now installed 3DS Max 2012 Student Edition. All attempts to get it to work have failed. Every time I start up, it crashes at the exact same time, as it's loading a plugin called HSDS.dlm.
Need help with this.
Hello. Generic error so far. Do the basics:
1.) Uninstall and reinstall.
2.) Update your graphics card drivers
3.) Download a new copy of the file
4.) Turn off Antivirus
5.) Look in the Windows event viewer for failures and search google for the failures, it may point to another program
I also found a similar post:
Thank you for taking part in our community!
Using the method in the post you mentioned above, I tried renaming the file I found in STDplug. Didn't work. So I tried moving it to Plugin conf (The destination it's apparently supposed to be in?), and now it starts up.
Not sure if this is going to bite me in the **** later, but if the issue could be looked into to find out if this is the ideal solution, I would greatly appreciate it.
