Installation & Licensing
3ds max 2011 x64 crashes after splash screen
4 REPLIES 4
solarnoise
722 Views, 4 Replies
Hi all,
I am using a student license which activated just fine.
My install of Max 2011 x64 WAS working fine on this machine a while ago... I recently attempted to launch it after downloading some other Autodesk projects (Maya, Motionbuilder, Modo), and now my Max 2011 will not open.
After the splash screen gets to "Starting 3ds Max..." the program fails to launch and I get the "3ds Max Error Report" window.
I have tried uninstalling and doing a clean reinstall, and it still does this.
I tried installing Max 2013 x64 and it WORKS... but I want to be able to use the 2011 version.
My computer:
Windows 7 x64
Intel E8400 @ 3.4 GHz
4GB RAM
Nvidia GTX 260
4 REPLIES 4
TravisNave
in reply to: solarnoise
Start by updating to a WHQL certified driver here:
http://www.nvidia.com/object/win8-win7-winvista-64bit-314.22-whql-driver.html
Perform a clean install when prompted.  It will take a reboot to finish installation.
Then you might have to do a repair install of 2011.  Check to see if there are any service packs afterwards.  Good luck!
Autodesk Forums:
solarnoise
in reply to: TravisNave
I did a clean install of 2011 x64 and x32.  I also did a clean install of the latest WHQL graphics driver.
x64 still does not load after the splash screen.  It gets past "Starting.." and then I get the "report a crash" screen.
x32 does load, but shows me an error first (attached screenshot) and  then asks if I want to restore the ribbon to defaults.  It does this every time.
Any help?  I can use x32 but I'd really like to know why x64 won't open.  My machine is very "clean" and I use antivirus/antimalware and I am the administrator.  My other Autodesk products work fine.
TravisNave
solarnoise
I did that and still get the error. but at least 32-bit opens fine after the error prompt.
Any ideas on how to get 64-bit to launch?
Administrator Productivity
