Installation & Licensing
New Member
aztech2100
Message 11 of 22 (7,180 Views)
Re: 3ds Max 2011 "Software License Checkout Failed Error 20"
02-22-2012 05:28 PM in reply to: Shad0wforce
I've tried messing around with the FLEXnet garbage and I can't seem to rid of this "error 20" that keeps popping up. I've tried with FLEXnet enabled, and I've tried with it disabled, either way I still get the error. *Also I no longer have my product code to reinstall max since I'm stupid, so is there a way I can fix this without having to purchase a 2nd copy?*
TravisNave
Message 12 of 22 (7,155 Views)
02-24-2012 07:09 AM in reply to: aztech2100
Make sure you give Everyone full rights to the following folders/files:
C:\ProgramData\FLEXnet\adskflex_*.data
C:\ProgramData\FLEXnet\adskflex_*.data.backup
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
Peterga
Message 13 of 22 (5,986 Views)
05-25-2012 06:41 AM in reply to: Shad0wforce
Gracia Carlos
Valued Contributor
hike1
Message 14 of 22 (5,361 Views)
Re: SOLUCION to "Software License Checkout Failed Error 20"
07-29-2012 10:26 AM in reply to: K4RL02
I got this error after I tried to install the Adobe CS4 demo, it puts a file in that flex directory which must confuse
3ds max. Never got the demo running either.
Member
rangel_designer
Message 15 of 22 (5,192 Views)
08-29-2012 08:02 PM in reply to: Shad0wforce
Help me, after all install be ok, when i got to run the program, i receive this message :smileyfrustrated:
Member
rangel_designer
Message 16 of 22 (5,191 Views)
08-29-2012 08:03 PM in reply to: rangel_designer
PS: ERRO 05!!!!!!
TravisNave
Message 17 of 22 (5,141 Views)
09-05-2012 11:12 AM in reply to: rangel_designer
New Member
sudhakar
Message 18 of 22 (5,090 Views)
09-11-2012 12:16 AM in reply to: leaveAlone
Thanks for the solution.
It worked for me in 3ds Max 2012. The Flexnet license services were stopped permanently. I just restarted & assigned to Start automatically.
Thus its working fine now !
Thanks !!
Member
_AKS_
Message 19 of 22 (3,366 Views)
06-02-2013 04:28 AM in reply to: Shad0wforce
Delete "C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data" it will solve the problem
New Member
107348860
Message 20 of 22 (2,581 Views)
10-08-2013 01:15 PM in reply to: _AKS_
I did the same as _AKS_ just said, simply deleting both C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data and C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data_backup.001 and reloading 3ds Max, then when it loads it recreates the files and the server, this was for 3DS Max 2012 though
