When I install 2011 max on to my machine, all is well, as soon as I apply the hotfix 4, all four of my veiwports turn black, the user interface remains grey and can still load, but cannot see anything even though I can click in the veiw ports and see, the mesh drop down activate for modelling, nothing is visible.
I am using windows 7 on a quad core and have checked that my hardware is up to date, I have di-o-matic and am thinking maybe that has something to do with it, when I first start it up, it gives me the reset to default ui, then when I answer yes or no, have tried everal dufferent ways, it simply turns the viewports black, grrrrr
Please help, have resorted to the original and do not intend to service pack the software or update till theres another fix for the fix lol
I just downloaded the free trial OF 3DS MAX design 2011 AND CANNOT SEE ANYTHING CREATED IN THE VIEWPORTS. They are gray and sometimes turn black. Please explain what I am doing wrong...or is this some type of software glitch. Thx
i get this error when i tried to install hotfix 4 for my 3ds max 2011 64 bit
"the upgrade patch cannot be installed by the windows installer because the program to be upgraded may be missing, or the upgrade patch may update a different version of the program. Verify that the program to be upgraded exist on your computer and that you have the correct upgrade pacth."
i was hoping this patch can resolve 3ds max 2011 problem with:
-snaps suddenly not working
-jittery viewport
-when i tried to transform (move) objects, suddenly it jumps to different location than i intended
I get the same error when trying to install the hotfix and I also have an issue with snaps not working.
