Hello.
I've been having a "variant" of a very common problem relating activation in 3DS MAX 2011. When I click activate I get a blank window... a tottaly empty, gray, with no radio buttons, window, like this:
I've tried everything... editing windows registry, reseting Internet explorer security settings to defaults, registering jscript.dll and vbscript.dll, activationg through a new admin/user account... I've done it all. I'm desperate.
What am I missing?
I have Windows Vista 32, Comodo firewall, Avast antivirus. Intel i-7 920, 3GB Ram, 2xNvidia 285 GTX (sli), Asus 27" monitor.
... Help!...
PR
Solved by PR01. Go to Solution.
please try in diagnostics mode.
what is the IE version ?
Thank you for the reply.
My Internet version: 8 (8.0.6001.19019). What do you mean with "try in diagnostiscs mode"?
PR
please try to uninstall IE 8 for the activation. it should work with IE7
diagnostics mode explained here
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404186&linkID=9240617
Well... it didn't work.
I unnistalled IE8, activated the ActiveX controls, re-registered the dlls and... nothing. Still the same gray empty window.
PR
Sorry about it not working.
I assume you have the same results in diagnostics mode as true windows admin user.
i found another work around for this in past, please try
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5582168&linkID=9241177
Yes, Please try IE as default.
#$%&! I found it! I just remembered to deactivate firewall and antivirus (I was almost certain i had tried that already). It was the firewall... it was blocking the **** thing!
Well, one thing led to the other... thanx!
PR
thanks for sharing the solution. so comodo firewall can cause issue : could you specify the version please..
thank you. Running in diagnostics mode should have taken care of the firewall.. anyways, glad it got fixed..
Gday mate I'm no techie but this worked for me. Create a new user and give them administration rights download or open the program in this user but when windows asks you install windows updates decline cause as far as i can tell it see's the activation page as a random number do dad and will block it.
should just follow normal steps from there and after you can delete user.
hope it helps
peace
