CPU-Z TXT Report ------------------------------------------------------------------------- Binaries ------------------------------------------------------------------------- CPU-Z version 1.64.0.x64 Processors ------------------------------------------------------------------------- Number of processors 1 Number of threads 6 APICs ------------------------------------------------------------------------- Processor 0 -- Core 0 -- Thread 0 0 -- Core 1 -- Thread 0 1 -- Core 2 -- Thread 0 2 -- Core 3 -- Thread 0 3 -- Core 4 -- Thread 0 4 -- Core 5 -- Thread 0 5 Timers ------------------------------------------------------------------------- ACPI timer 3.580 MHz HPET timer 14.318 MHz Perf timer 3.136 MHz Sys timer 1.000 KHz BCLK timer 200.67 MHz Processors Information ------------------------------------------------------------------------- Processor 1 ID = 0 Number of cores 6 (max 6) Number of threads 6 (max 6) Name AMD Phenom II X6 1090T Codename Thuban Specification AMD Phenom(tm) II X6 1090T Processor Package Socket AM3 (938) CPUID F.A.0 Extended CPUID 10.A Core Stepping PH-E0 Technology 45 nm TDP Limit 126 Watts Core Speed 1605.3 MHz Multiplier x Bus Speed 8.0 x 200.7 MHz HT Link speed 2006.7 MHz Stock frequency 3200 MHz Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V L1 Data cache 6 x 64 KBytes, 2-way set associative, 64-byte line size L1 Instruction cache 6 x 64 KBytes, 2-way set associative, 64-byte line size L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size L3 cache 6 MBytes, 48-way set associative, 64-byte line size FID/VID Control yes Min FID 4.0x # of P-States 5 P-State FID 0x14 - VID 0x06 - IDD 16 (18.00x - 1.475 V) P-State FID 0x10 - VID 0x0C - IDD 16 (16.00x - 1.400 V) P-State FID 0x8 - VID 0x10 - IDD 12 (12.00x - 1.350 V) P-State FID 0x0 - VID 0x14 - IDD 8 (8.00x - 1.300 V) P-State FID 0x100 - VID 0x1A - IDD 5 (4.00x - 1.225 V) Package Type 0x1 Model 09 String 1 0x0 String 2 0x1 Page 0x0 CmpCap 6 ApicIdCoreSize 8 TDC Limit 96 Amps Boosted P-States 1 Max non-turbo ratio 16.00x Max turbo ratio 18.00x Core Performance Boost yes P-State 1, FID 0x100 - VID 0x1A (4.00x - 1.225 V) Attached device PCI device at bus 0, device 24, function 0 Attached device PCI device at bus 0, device 24, function 1 Attached device PCI device at bus 0, device 24, function 2 Attached device PCI device at bus 0, device 24, function 3 Attached device PCI device at bus 0, device 24, function 4 TSC 3210.6 MHz APERF 1605.4 MHz MPERF 3210.5 MHz PERFEVT 1605.3 MHz Thread dumps ------------------------------------------------------------------------- CPU Thread 0 APIC ID 0 Topology Processor ID 0, Core ID 0, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x00060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00900 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000002 MSR 0xC0010063 0x00000000 0x00000003 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01000001 0x3C032800 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x01000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800 CPU Thread 1 APIC ID 1 Topology Processor ID 0, Core ID 1, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x01060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000002 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x00000001 0x3C043440 MSR 0xC0010070 0x00000000 0x3C043440 CPU Thread 2 APIC ID 2 Topology Processor ID 0, Core ID 2, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x02060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000002 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x00000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800 CPU Thread 3 APIC ID 3 Topology Processor ID 0, Core ID 3, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x03060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000002 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x01000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800 CPU Thread 4 APIC ID 4 Topology Processor ID 0, Core ID 4, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x04060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000003 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x00000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800 CPU Thread 5 APIC ID 5 Topology Processor ID 0, Core ID 5, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x05060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000003 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x01000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800 Chipset ------------------------------------------------------------------------- Northbridge AMD 870 rev. 00 Southbridge AMD SB850 rev. 40 Graphic Interface PCI-Express PCI-E Link Width x16 PCI-E Max Link Width x16 Memory Type DDR3 Memory Size 16384 MBytes Channels Dual, (Unganged) Memory Frequency 668.9 MHz (3:10) CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Bank Cycle Time (tRC) 33 Command Rate (CR) 2T Uncore Frequency 2006.7 MHz Memory SPD ------------------------------------------------------------------------- DIMM # 1 SMBus address 0x50 Memory type DDR3 Module format UDIMM Manufacturer (ID) G.Skill (7F7F7F7FCD000000) Size 4096 MBytes Max bandwidth PC3-10700 (667 MHz) Part number F3-10666CL9-4GBRL Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHz DIMM # 2 SMBus address 0x51 Memory type DDR3 Module format UDIMM Manufacturer (ID) G.Skill (7F7F7F7FCD000000) Size 4096 MBytes Max bandwidth PC3-10700 (667 MHz) Part number F3-10666CL9-4GBRL Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHz DIMM # 3 SMBus address 0x52 Memory type DDR3 Module format UDIMM Manufacturer (ID) G.Skill (7F7F7F7FCD000000) Size 4096 MBytes Max bandwidth PC3-10700 (667 MHz) Part number F3-10666CL9-4GBRL Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHz DIMM # 4 SMBus address 0x53 Memory type DDR3 Module format UDIMM Manufacturer (ID) G.Skill (7F7F7F7FCD000000) Size 4096 MBytes Max bandwidth PC3-10700 (667 MHz) Part number F3-10666CL9-4GBRL Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHz DIMM # 1 SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0 80 46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52 90 4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DIMM # 2 SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0 80 46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52 90 4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DIMM # 3 SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0 80 46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52 90 4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DIMM # 4 SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0 80 46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52 90 4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Monitoring ------------------------------------------------------------------------- Mainboard Model M4A87TD/USB3 (0x00000315 - 0x5C947A60) LPCIO ------------------------------------------------------------------------- LPCIO Vendor ITE LPCIO Model IT8721 LPCIO Vendor ID 0x90 LPCIO Chip ID 0x8721 LPCIO Revision ID 0x1 Config Mode I/O address 0x2E Config Mode LDN 0x4 Config Mode registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 87 21 01 00 00 06 80 00 00 00 00 00 9F 00 00 00 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00 70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00 Register space LPC, base address = 0x0290 Hardware Monitors ------------------------------------------------------------------------- Hardware monitor ITE IT8721 Voltage 0 11.68 Volts [0xEA] (+12V) Voltage 1 4.87 Volts [0xE8] (+5V) Voltage 2 1.26 Volts [0x69] (CPU VCORE) Voltage 3 1.67 Volts [0x8B] (VIN3) Voltage 4 2.87 Volts [0xEF] (VIN4) Voltage 5 3.72 Volts [0xF8] (+3.3V) Voltage 6 2.40 Volts [0xC8] (VIN6) Voltage 7 0.48 Volts [0x28] (VIN7) Voltage 8 1.68 Volts [0x8C] (VIN8) Temperature 0 45°C (113°F) [0x2D] (CPU) Temperature 1 37°C (98°F) [0x25] (Mainboard) Fan 0 650 RPM [0x40F] (CPU) Fan PWM 0 0 pc [0x0] (FANPWM0) Fan PWM 1 0 pc [0x0] (FANPWM1) Fan PWM 2 0 pc [0x0] (FANPWM2) Register space LPC, base address = 0x0290 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 11 06 F7 03 37 FF 07 37 FF 07 58 0F 07 0F FF FF 10 C4 0B E7 7F C7 80 00 00 04 FF FF A4 7B 9A 9A 9A 20 EA E8 63 8A EF F8 C8 28 8C 2D 25 80 80 C0 F1 F1 30 37 15 20 12 06 2B 92 17 43 44 2C 25 A8 B9 89 9A 40 E9 FD 1B 0F B5 E4 5F 40 AD 6A D4 00 FF FF FF FF 50 0F 18 7F 7F 7F 40 56 56 90 56 3D 12 E0 00 00 00 60 80 14 46 0C A0 41 00 FF 80 00 7F FF 00 41 00 FF 70 80 00 7F FF 00 41 00 FF FF FF FF FF FF FF FF FF 80 00 00 00 00 00 00 00 00 00 00 00 00 00 64 02 80 90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF A0 28 12 12 12 12 12 12 FF FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF PCI Devices ------------------------------------------------------------------------- Description Host Bridge Location bus 0 (0x00), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x1002 Model ID 0x5957 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 3 (memory) 0xE0000000 Subvendor ID 0x1002 Subsystem ID 0x5957 Int. Line 0x00 Int. Pin 0x00 PCI capability Caps class HyperTransport Caps offset 0xC4 Caps revision 3.00 Interface type Slave/Primary Link 0 width (in/out) 16 bits/16 bits Link 0 frequency 2000 MHz Link 1 width (in/out) 8 bits/8 bits Link 1 frequency 200 MHz PCI capability Caps class HyperTransport Caps offset 0x40 Interface type Retry Mode PCI capability Caps class HyperTransport Caps offset 0x54 Interface type Clumping PCI capability Caps class HyperTransport Caps offset 0x9C Interface type Gen3 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 57 59 06 00 30 22 00 00 00 06 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 E0 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 57 59 30 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 40 08 54 00 C0 C1 00 00 00 00 00 00 00 42 20 05 00 50 02 10 57 59 08 9C 00 90 08 10 00 00 00 00 00 00 60 7D 00 00 00 E3 00 00 00 00 02 20 00 61 4F 00 78 70 00 00 00 00 00 00 00 00 8C 9D 0F 00 00 00 00 00 80 00 00 00 00 10 00 00 03 20 01 30 00 31 20 00 40 90 00 00 00 D0 7D 00 00 00 00 00 00 00 08 00 3C D0 A0 82 00 00 00 00 00 00 86 00 00 00 00 79 40 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 80 08 40 80 01 20 01 11 11 D0 00 00 00 D0 60 0B F5 7F 02 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 05 00 FF FF FF FF 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 80 80 00 00 00 00 00 00 00 00 00 Description PCI to PCI Bridge Location bus 0 (0x00), device 2 (0x02), function 0 (0x00) Common header Vendor ID 0x1002 Model ID 0x5978 Revision ID 0x00 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x10 Latency 0x00 Header 0x01 PCI header Primary bus 0x00 Secondary bus 0x05 Int. Line 0x00 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2 PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Port of PCI-E Root Complex Port 0 Version 2.0 Physical slot #0 Presence detect yes Link width 16x (max 16x) PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0 PCI capability Caps class Subsystem Vendor Caps offset 0xB0 SubVendor ID 0x1002 SubSystem ID 0x5957 PCI capability Caps class HyperTransport Caps offset 0xB8 Interface type MSI Mapping Extended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 Caps class Virtual Channel Caps offset 0x110 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 78 59 07 05 10 00 00 00 04 06 10 00 01 00 10 00 00 00 00 00 00 00 00 00 05 05 00 E1 E1 00 20 20 00 FD 90 FE 01 D6 F1 DF 00 00 00 00 00 00 00 00 30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 1B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 60 10 09 00 00 02 0D 30 00 41 00 01 71 80 25 14 00 70 00 00 48 01 08 00 01 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 B0 01 00 0C F0 E3 FE A0 49 00 00 00 00 00 00 B0 0D B8 00 00 02 10 57 59 08 00 03 A8 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 50 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description PCI to PCI Bridge Location bus 0 (0x00), device 9 (0x09), function 0 (0x00) Common header Vendor ID 0x1002 Model ID 0x597E Revision ID 0x00 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x10 Latency 0x00 Header 0x01 PCI header Primary bus 0x00 Secondary bus 0x04 Int. Line 0x00 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2 PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Port of PCI-E Root Complex Port 1 Version 2.0 Physical slot #1 Presence detect yes Link width 1x (max 2x) PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0 PCI capability Caps class Subsystem Vendor Caps offset 0xB0 SubVendor ID 0x1002 SubSystem ID 0x5957 PCI capability Caps class HyperTransport Caps offset 0xB8 Interface type MSI Mapping Extended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 Caps class Virtual Channel Caps offset 0x110 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 7E 59 05 05 10 00 00 00 04 06 10 00 01 00 10 00 00 00 00 00 00 00 00 00 04 04 00 D1 D1 00 20 20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00 30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 07 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 60 10 01 00 00 22 0C 30 01 40 00 11 70 80 0C 4C 00 70 00 00 48 01 08 00 01 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 B0 01 00 0C F0 E3 FE 90 49 00 00 00 00 00 00 B0 0D B8 00 00 02 10 57 59 08 00 03 A8 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 50 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description PCI to PCI Bridge Location bus 0 (0x00), device 10 (0x0A), function 0 (0x00) Common header Vendor ID 0x1002 Model ID 0x597F Revision ID 0x00 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x10 Latency 0x00 Header 0x01 PCI header Primary bus 0x00 Secondary bus 0x03 Int. Line 0x00 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2 PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Port of PCI-E Root Complex Port 2 Version 2.0 Physical slot #1 Presence detect yes Link width 1x (max 2x) PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0 PCI capability Caps class Subsystem Vendor Caps offset 0xB0 SubVendor ID 0x1002 SubSystem ID 0x5957 PCI capability Caps class HyperTransport Caps offset 0xB8 Interface type MSI Mapping Extended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 Caps class Virtual Channel Caps offset 0x110 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 7F 59 06 05 10 00 00 00 04 06 10 00 01 00 10 00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 20 20 F0 FC F0 FC F1 FF 01 00 00 00 00 00 00 00 00 00 30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 07 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 60 10 01 00 00 22 0C 30 02 40 00 12 70 80 0C 54 00 70 00 00 48 01 08 00 01 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 B0 01 00 0C F0 E3 FE 80 49 00 00 00 00 00 00 B0 0D B8 00 00 02 10 57 59 08 00 03 A8 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 50 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description IDE Controller Location bus 0 (0x00), device 17 (0x11), function 0 (0x00) Common header Vendor ID 0x1002 Model ID 0x4390 Revision ID 0x40 PI 0x8F SubClass 0x01 BaseClass 0x01 Cache Line 0x10 Latency 0x40 Header 0x00 PCI header Address 0 (port) 0x0000B000 Address 1 (port) 0x0000A000 Address 2 (port) 0x00009000 Address 3 (port) 0x00008000 Address 4 (port) 0x00007000 Address 5 (memory) 0xFCEFA000 Subvendor ID 0x1002 Subsystem ID 0x4390 Int. Line 0x13 Int. Pin 0x01 PCI capability Caps class Message Signalled Interrupts Caps offset 0x50 PCI capability Caps class 0x12 Caps offset 0x70 PCI capability Caps class 0x13 Caps offset 0xA4 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 90 43 07 01 30 02 40 8F 01 01 10 40 00 00 10 01 B0 00 00 01 A0 00 00 01 90 00 00 01 80 00 00 20 01 70 00 00 00 A0 EF FC 00 00 00 00 02 10 90 43 30 00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00 40 14 80 80 00 01 00 20 00 00 00 80 00 00 00 00 00 50 05 70 84 00 00 00 00 00 00 00 00 00 00 00 00 00 60 01 50 22 00 00 00 00 00 00 00 00 00 00 00 00 00 70 12 A4 10 00 0F 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 06 1A 14 00 AB 01 08 00 F0 00 00 00 90 27 60 74 C7 02 43 00 00 08 01 00 00 01 58 11 08 A0 0C 00 00 00 13 00 06 03 00 00 64 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 E0 80 00 00 00 00 00 00 00 00 00 00 00 10 00 00 3F F0 00 00 00 00 00 00 00 00 77 77 77 00 00 00 00 00 Description USB Controller (OHCI) Location bus 0 (0x00), device 18 (0x12), function 0 (0x00) Common header Vendor ID 0x1002 Model ID 0x4397 Revision ID 0x00 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x40 Header 0x80 PCI header Address 0 (memory) 0xFCEF3000 Subvendor ID 0x1002 Subsystem ID 0x4397 Int. Line 0x12 Int. Pin 0x01 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 97 43 16 01 A0 02 00 10 03 0C 10 40 80 00 10 00 30 EF FC 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 97 43 30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 50 40 00 00 F0 00 00 00 00 10 F2 FF FF 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB 2.0 Controller (EHCI) Location bus 0 (0x00), device 18 (0x12), function 2 (0x02) Common header Vendor ID 0x1002 Model ID 0x4396 Revision ID 0x00 PI 0x20 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x40 Header 0x00 PCI header Address 0 (memory) 0xFCEFA400 Subvendor ID 0x1002 Subsystem ID 0x4396 Int. Line 0x11 Int. Pin 0x02 PCI capability Caps class Power Management Caps offset 0xC0 Caps version 1.1 PCI capability Caps class Debug Port Caps offset 0xE4 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 96 43 06 01 B0 02 00 20 03 0C 10 40 00 00 10 00 A4 EF FC 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 96 43 30 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 40 21 80 A0 01 00 00 00 00 00 00 00 00 00 00 00 60 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00 A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB Controller (OHCI) Location bus 0 (0x00), device 19 (0x13), function 0 (0x00) Common header Vendor ID 0x1002 Model ID 0x4397 Revision ID 0x00 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x40 Header 0x80 PCI header Address 0 (memory) 0xFCEF8000 Subvendor ID 0x1002 Subsystem ID 0x4397 Int. Line 0x12 Int. Pin 0x01 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 97 43 16 01 A0 02 00 10 03 0C 10 40 80 00 10 00 80 EF FC 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 97 43 30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 50 40 00 00 F0 00 00 00 00 43 FF FF FF 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CPU-Z TXT Report-------------------------------------------------------------------------Binaries-------------------------------------------------------------------------CPU-Z version 1.64.0.x64Processors-------------------------------------------------------------------------Number of processors 1Number of threads 6APICs-------------------------------------------------------------------------Processor 0 -- Core 0 -- Thread 0 0 -- Core 1 -- Thread 0 1 -- Core 2 -- Thread 0 2 -- Core 3 -- Thread 0 3 -- Core 4 -- Thread 0 4 -- Core 5 -- Thread 0 5Timers------------------------------------------------------------------------- ACPI timer 3.580 MHz HPET timer 14.318 MHz Perf timer 3.136 MHz Sys timer 1.000 KHz BCLK timer 200.67 MHzProcessors Information-------------------------------------------------------------------------Processor 1 ID = 0 Number of cores 6 (max 6) Number of threads 6 (max 6) Name AMD Phenom II X6 1090T Codename Thuban Specification AMD Phenom(tm) II X6 1090T Processor Package Socket AM3 (938) CPUID F.A.0 Extended CPUID 10.A Core Stepping PH-E0 Technology 45 nm TDP Limit 126 Watts Core Speed 1605.3 MHz Multiplier x Bus Speed 8.0 x 200.7 MHz HT Link speed 2006.7 MHz Stock frequency 3200 MHz Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V L1 Data cache 6 x 64 KBytes, 2-way set associative, 64-byte line size L1 Instruction cache 6 x 64 KBytes, 2-way set associative, 64-byte line size L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size L3 cache 6 MBytes, 48-way set associative, 64-byte line size FID/VID Control yes Min FID 4.0x # of P-States 5 P-State FID 0x14 - VID 0x06 - IDD 16 (18.00x - 1.475 V) P-State FID 0x10 - VID 0x0C - IDD 16 (16.00x - 1.400 V) P-State FID 0x8 - VID 0x10 - IDD 12 (12.00x - 1.350 V) P-State FID 0x0 - VID 0x14 - IDD 8 (8.00x - 1.300 V) P-State FID 0x100 - VID 0x1A - IDD 5 (4.00x - 1.225 V) Package Type 0x1 Model 09 String 1 0x0 String 2 0x1 Page 0x0 CmpCap 6 ApicIdCoreSize 8 TDC Limit 96 Amps Boosted P-States 1 Max non-turbo ratio 16.00x Max turbo ratio 18.00x Core Performance Boost yes P-State 1, FID 0x100 - VID 0x1A (4.00x - 1.225 V) Attached device PCI device at bus 0, device 24, function 0 Attached device PCI device at bus 0, device 24, function 1 Attached device PCI device at bus 0, device 24, function 2 Attached device PCI device at bus 0, device 24, function 3 Attached device PCI device at bus 0, device 24, function 4 TSC 3210.6 MHz APERF 1605.4 MHz MPERF 3210.5 MHz PERFEVT 1605.3 MHzThread dumps-------------------------------------------------------------------------CPU Thread 0 APIC ID 0 Topology Processor ID 0, Core ID 0, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x00060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00900 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000002 MSR 0xC0010063 0x00000000 0x00000003 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01000001 0x3C032800 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x01000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800CPU Thread 1 APIC ID 1 Topology Processor ID 0, Core ID 1, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x01060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000002 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x00000001 0x3C043440 MSR 0xC0010070 0x00000000 0x3C043440CPU Thread 2 APIC ID 2 Topology Processor ID 0, Core ID 2, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x02060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000002 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x00000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800CPU Thread 3 APIC ID 3 Topology Processor ID 0, Core ID 3, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x03060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000002 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x01000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800CPU Thread 4 APIC ID 4 Topology Processor ID 0, Core ID 4, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x04060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000003 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x00000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800CPU Thread 5 APIC ID 5 Topology Processor ID 0, Core ID 5, Thread ID 0 Type 02004010h Max CPUID level 00000006h Max CPUID ext. level 8000001Bh Cache descriptor Level 1, I, 64 KB, 1 thread(s) Cache descriptor Level 1, D, 64 KB, 1 thread(s) Cache descriptor Level 2, U, 512 KB, 1 thread(s) Cache descriptor Level 3, U, 6 MB, 6 thread(s) CPUID 0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00100FA0 0x05060800 0x00802009 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00100FA0 0x10000091 0x000037FF 0xEFD3FBFF 0x80000002 0x20444D41 0x6E656850 0x74286D6F 0x4920296D 0x80000003 0x36582049 0x39303120 0x50205430 0x65636F72 0x80000004 0x726F7373 0x00000000 0x00000000 0x00000000 0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140 0x80000006 0x20800000 0x42004200 0x02008140 0x0030B140 0x80000007 0x00000000 0x00000000 0x00000000 0x000003F9 0x80000008 0x00003030 0x00000000 0x00003005 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000030 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000003 MSR 0xC0010064 0x8000019E 0x3C000C14 MSR 0xC0010065 0x8000019F 0x3C001810 MSR 0xC0010066 0x80000175 0x3C002008 MSR 0xC0010067 0x80000154 0x3C002800 MSR 0xC0010068 0x80000135 0x3C003440 MSR 0xC0010071 0x01800001 0x3C011810 MSR 0xC0010015 0x00000000 0x01000010 MSR 0xC001001F 0x00584000 0x00000008 MSR 0xC0010058 0x00000000 0xE0000021 MSR 0xC0010071 0x01000001 0x3C032800 MSR 0xC0010070 0x00000000 0x3C032800Chipset-------------------------------------------------------------------------Northbridge AMD 870 rev. 00Southbridge AMD SB850 rev. 40Graphic Interface PCI-ExpressPCI-E Link Width x16PCI-E Max Link Width x16Memory Type DDR3Memory Size 16384 MBytesChannels Dual, (Unganged)Memory Frequency 668.9 MHz (3:10)CAS# latency (CL) 9.0RAS# to CAS# delay (tRCD) 9RAS# Precharge (tRP) 9Cycle Time (tRAS) 24Bank Cycle Time (tRC) 33Command Rate (CR) 2TUncore Frequency 2006.7 MHzMemory SPD-------------------------------------------------------------------------DIMM # 1 SMBus address 0x50 Memory type DDR3 Module format UDIMM Manufacturer (ID) G.Skill (7F7F7F7FCD000000) Size 4096 MBytes Max bandwidth PC3-10700 (667 MHz) Part number F3-10666CL9-4GBRL Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP noJEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHzDIMM # 2 SMBus address 0x51 Memory type DDR3 Module format UDIMM Manufacturer (ID) G.Skill (7F7F7F7FCD000000) Size 4096 MBytes Max bandwidth PC3-10700 (667 MHz) Part number F3-10666CL9-4GBRL Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP noJEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHzDIMM # 3 SMBus address 0x52 Memory type DDR3 Module format UDIMM Manufacturer (ID) G.Skill (7F7F7F7FCD000000) Size 4096 MBytes Max bandwidth PC3-10700 (667 MHz) Part number F3-10666CL9-4GBRL Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP noJEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHzDIMM # 4 SMBus address 0x53 Memory type DDR3 Module format UDIMM Manufacturer (ID) G.Skill (7F7F7F7FCD000000) Size 4096 MBytes Max bandwidth PC3-10700 (667 MHz) Part number F3-10666CL9-4GBRL Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP noJEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHzDIMM # 1SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0 80 46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52 90 4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00DIMM # 2SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0 80 46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52 90 4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00DIMM # 3SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0 80 46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52 90 4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00DIMM # 4SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0 80 46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52 90 4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Monitoring-------------------------------------------------------------------------Mainboard Model M4A87TD/USB3 (0x00000315 - 0x5C947A60)LPCIO-------------------------------------------------------------------------LPCIO Vendor ITELPCIO Model IT8721LPCIO Vendor ID 0x90LPCIO Chip ID 0x8721LPCIO Revision ID 0x1Config Mode I/O address 0x2EConfig Mode LDN 0x4Config Mode registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 87 21 01 00 00 06 80 00 00 00 00 00 9F 00 00 00 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00 70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00Register space LPC, base address = 0x0290Hardware Monitors-------------------------------------------------------------------------Hardware monitor ITE IT8721 Voltage 0 11.68 Volts [0xEA] (+12V) Voltage 1 4.87 Volts [0xE8] (+5V) Voltage 2 1.26 Volts [0x69] (CPU VCORE) Voltage 3 1.67 Volts [0x8B] (VIN3) Voltage 4 2.87 Volts [0xEF] (VIN4) Voltage 5 3.72 Volts [0xF8] (+3.3V) Voltage 6 2.40 Volts [0xC8] (VIN6) Voltage 7 0.48 Volts [0x28] (VIN7) Voltage 8 1.68 Volts [0x8C] (VIN8) Temperature 0 45°C (113°F) [0x2D] (CPU) Temperature 1 37°C (98°F) [0x25] (Mainboard) Fan 0 650 RPM [0x40F] (CPU) Fan PWM 0 0 pc [0x0] (FANPWM0) Fan PWM 1 0 pc [0x0] (FANPWM1) Fan PWM 2 0 pc [0x0] (FANPWM2)Register space LPC, base address = 0x0290 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 11 06 F7 03 37 FF 07 37 FF 07 58 0F 07 0F FF FF 10 C4 0B E7 7F C7 80 00 00 04 FF FF A4 7B 9A 9A 9A 20 EA E8 63 8A EF F8 C8 28 8C 2D 25 80 80 C0 F1 F1 30 37 15 20 12 06 2B 92 17 43 44 2C 25 A8 B9 89 9A 40 E9 FD 1B 0F B5 E4 5F 40 AD 6A D4 00 FF FF FF FF 50 0F 18 7F 7F 7F 40 56 56 90 56 3D 12 E0 00 00 00 60 80 14 46 0C A0 41 00 FF 80 00 7F FF 00 41 00 FF 70 80 00 7F FF 00 41 00 FF FF FF FF FF FF FF FF FF 80 00 00 00 00 00 00 00 00 00 00 00 00 00 64 02 80 90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF A0 28 12 12 12 12 12 12 FF FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FFPCI Devices-------------------------------------------------------------------------Description Host BridgeLocation bus 0 (0x00), device 0 (0x00), function 0 (0x00)Common header Vendor ID 0x1002 Model ID 0x5957 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x00PCI header Address 3 (memory) 0xE0000000 Subvendor ID 0x1002 Subsystem ID 0x5957 Int. Line 0x00 Int. Pin 0x00PCI capability Caps class HyperTransport Caps offset 0xC4 Caps revision 3.00 Interface type Slave/Primary Link 0 width (in/out) 16 bits/16 bits Link 0 frequency 2000 MHz Link 1 width (in/out) 8 bits/8 bits Link 1 frequency 200 MHzPCI capability Caps class HyperTransport Caps offset 0x40 Interface type Retry ModePCI capability Caps class HyperTransport Caps offset 0x54 Interface type ClumpingPCI capability Caps class HyperTransport Caps offset 0x9C Interface type Gen3PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 57 59 06 00 30 22 00 00 00 06 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 E0 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 57 59 30 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 40 08 54 00 C0 C1 00 00 00 00 00 00 00 42 20 05 00 50 02 10 57 59 08 9C 00 90 08 10 00 00 00 00 00 00 60 7D 00 00 00 E3 00 00 00 00 02 20 00 61 4F 00 78 70 00 00 00 00 00 00 00 00 8C 9D 0F 00 00 00 00 00 80 00 00 00 00 10 00 00 03 20 01 30 00 31 20 00 40 90 00 00 00 D0 7D 00 00 00 00 00 00 00 08 00 3C D0 A0 82 00 00 00 00 00 00 86 00 00 00 00 79 40 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 80 08 40 80 01 20 01 11 11 D0 00 00 00 D0 60 0B F5 7F 02 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 05 00 FF FF FF FF 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 80 80 00 00 00 00 00 00 00 00 00Description PCI to PCI BridgeLocation bus 0 (0x00), device 2 (0x02), function 0 (0x00)Common header Vendor ID 0x1002 Model ID 0x5978 Revision ID 0x00 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x10 Latency 0x00 Header 0x01PCI header Primary bus 0x00 Secondary bus 0x05 Int. Line 0x00 Int. Pin 0x01PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Port of PCI-E Root Complex Port 0 Version 2.0 Physical slot #0 Presence detect yes Link width 16x (max 16x)PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0PCI capability Caps class Subsystem Vendor Caps offset 0xB0 SubVendor ID 0x1002 SubSystem ID 0x5957PCI capability Caps class HyperTransport Caps offset 0xB8 Interface type MSI MappingExtended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 Caps class Virtual Channel Caps offset 0x110PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 78 59 07 05 10 00 00 00 04 06 10 00 01 00 10 00 00 00 00 00 00 00 00 00 05 05 00 E1 E1 00 20 20 00 FD 90 FE 01 D6 F1 DF 00 00 00 00 00 00 00 00 30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 1B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 60 10 09 00 00 02 0D 30 00 41 00 01 71 80 25 14 00 70 00 00 48 01 08 00 01 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 B0 01 00 0C F0 E3 FE A0 49 00 00 00 00 00 00 B0 0D B8 00 00 02 10 57 59 08 00 03 A8 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 50 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description PCI to PCI BridgeLocation bus 0 (0x00), device 9 (0x09), function 0 (0x00)Common header Vendor ID 0x1002 Model ID 0x597E Revision ID 0x00 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x10 Latency 0x00 Header 0x01PCI header Primary bus 0x00 Secondary bus 0x04 Int. Line 0x00 Int. Pin 0x01PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Port of PCI-E Root Complex Port 1 Version 2.0 Physical slot #1 Presence detect yes Link width 1x (max 2x)PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0PCI capability Caps class Subsystem Vendor Caps offset 0xB0 SubVendor ID 0x1002 SubSystem ID 0x5957PCI capability Caps class HyperTransport Caps offset 0xB8 Interface type MSI MappingExtended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 Caps class Virtual Channel Caps offset 0x110PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 7E 59 05 05 10 00 00 00 04 06 10 00 01 00 10 00 00 00 00 00 00 00 00 00 04 04 00 D1 D1 00 20 20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00 30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 07 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 60 10 01 00 00 22 0C 30 01 40 00 11 70 80 0C 4C 00 70 00 00 48 01 08 00 01 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 B0 01 00 0C F0 E3 FE 90 49 00 00 00 00 00 00 B0 0D B8 00 00 02 10 57 59 08 00 03 A8 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 50 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description PCI to PCI BridgeLocation bus 0 (0x00), device 10 (0x0A), function 0 (0x00)Common header Vendor ID 0x1002 Model ID 0x597F Revision ID 0x00 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x10 Latency 0x00 Header 0x01PCI header Primary bus 0x00 Secondary bus 0x03 Int. Line 0x00 Int. Pin 0x01PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Port of PCI-E Root Complex Port 2 Version 2.0 Physical slot #1 Presence detect yes Link width 1x (max 2x)PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0PCI capability Caps class Subsystem Vendor Caps offset 0xB0 SubVendor ID 0x1002 SubSystem ID 0x5957PCI capability Caps class HyperTransport Caps offset 0xB8 Interface type MSI MappingExtended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 Caps class Virtual Channel Caps offset 0x110PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 7F 59 06 05 10 00 00 00 04 06 10 00 01 00 10 00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 20 20 F0 FC F0 FC F1 FF 01 00 00 00 00 00 00 00 00 00 30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 07 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 60 10 01 00 00 22 0C 30 02 40 00 12 70 80 0C 54 00 70 00 00 48 01 08 00 01 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 B0 01 00 0C F0 E3 FE 80 49 00 00 00 00 00 00 B0 0D B8 00 00 02 10 57 59 08 00 03 A8 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 50 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description IDE ControllerLocation bus 0 (0x00), device 17 (0x11), function 0 (0x00)Common header Vendor ID 0x1002 Model ID 0x4390 Revision ID 0x40 PI 0x8F SubClass 0x01 BaseClass 0x01 Cache Line 0x10 Latency 0x40 Header 0x00PCI header Address 0 (port) 0x0000B000 Address 1 (port) 0x0000A000 Address 2 (port) 0x00009000 Address 3 (port) 0x00008000 Address 4 (port) 0x00007000 Address 5 (memory) 0xFCEFA000 Subvendor ID 0x1002 Subsystem ID 0x4390 Int. Line 0x13 Int. Pin 0x01PCI capability Caps class Message Signalled Interrupts Caps offset 0x50PCI capability Caps class 0x12 Caps offset 0x70PCI capability Caps class 0x13 Caps offset 0xA4PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 90 43 07 01 30 02 40 8F 01 01 10 40 00 00 10 01 B0 00 00 01 A0 00 00 01 90 00 00 01 80 00 00 20 01 70 00 00 00 A0 EF FC 00 00 00 00 02 10 90 43 30 00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00 40 14 80 80 00 01 00 20 00 00 00 80 00 00 00 00 00 50 05 70 84 00 00 00 00 00 00 00 00 00 00 00 00 00 60 01 50 22 00 00 00 00 00 00 00 00 00 00 00 00 00 70 12 A4 10 00 0F 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 06 1A 14 00 AB 01 08 00 F0 00 00 00 90 27 60 74 C7 02 43 00 00 08 01 00 00 01 58 11 08 A0 0C 00 00 00 13 00 06 03 00 00 64 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 E0 80 00 00 00 00 00 00 00 00 00 00 00 10 00 00 3F F0 00 00 00 00 00 00 00 00 77 77 77 00 00 00 00 00Description USB Controller (OHCI)Location bus 0 (0x00), device 18 (0x12), function 0 (0x00)Common header Vendor ID 0x1002 Model ID 0x4397 Revision ID 0x00 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x40 Header 0x80PCI header Address 0 (memory) 0xFCEF3000 Subvendor ID 0x1002 Subsystem ID 0x4397 Int. Line 0x12 Int. Pin 0x01PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 97 43 16 01 A0 02 00 10 03 0C 10 40 80 00 10 00 30 EF FC 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 97 43 30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 50 40 00 00 F0 00 00 00 00 10 F2 FF FF 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description USB 2.0 Controller (EHCI)Location bus 0 (0x00), device 18 (0x12), function 2 (0x02)Common header Vendor ID 0x1002 Model ID 0x4396 Revision ID 0x00 PI 0x20 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x40 Header 0x00PCI header Address 0 (memory) 0xFCEFA400 Subvendor ID 0x1002 Subsystem ID 0x4396 Int. Line 0x11 Int. Pin 0x02PCI capability Caps class Power Management Caps offset 0xC0 Caps version 1.1PCI capability Caps class Debug Port Caps offset 0xE4PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 96 43 06 01 B0 02 00 20 03 0C 10 40 00 00 10 00 A4 EF FC 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 96 43 30 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 40 21 80 A0 01 00 00 00 00 00 00 00 00 00 00 00 60 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00 A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description USB Controller (OHCI)Location bus 0 (0x00), device 19 (0x13), function 0 (0x00)Common header Vendor ID 0x1002 Model ID 0x4397 Revision ID 0x00 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x40 Header 0x80PCI header Address 0 (memory) 0xFCEF8000 Subvendor ID 0x1002 Subsystem ID 0x4397 Int. Line 0x12 Int. Pin 0x01PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 97 43 16 01 A0 02 00 10 03 0C 10 40 80 00 10 00 80 EF FC 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 97 43 30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 50 40 00 00 F0 00 00 00 00 43 FF FF FF 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
