Installation & Licensing
New Member
iyer.kool
Message 1 of 9 (7,073 Views)
3ds Max 2010 fails to start due to biped dlc error
7073 Views, 8 Replies
02-23-2011 01:08 AM
3ds Max 2010 (32bit) fails to start up while loading when it starts to load biped dlc.  Why is this happening and what can be done to set it right?
Here is the technical solution http://usa.autodesk.com/getdoc/id=TS1071846
Please test resetting the BIPED.INI configuration file.
1. Close 3ds Max Design 2010 / 2011.
2. Browse to the following local user application preferences directory-
Windows VISTA / Windows 7
C:\Users\YOUR_USER_NAME\AppData\Local\Autodesk\3dsMaxDesign\2010 - 32bit\enu\plugcfg
Windows XP
C:\Documents and Settings\YOUR_USER_NAME\local settings\Autodesk\3dsMaxDesign\2010 - 32bit\enu\plugcfg
3. Rename the BIPED.INI configuration file in this direcrtory to OLD_BIPED.INI
4. Restart 3ds Max Design 2010, new user application preference file for Biped will be created on startup.
I hope that the above information is useful
Cheers
Product Support
anil.choudhary
Message 2 of 9 (7,049 Views)
Re: 3ds Max 2010 fails to start due to biped dlc error
02-23-2011 08:42 PM in reply to: iyer.kool
Windows XP
Cheers
Anil Choudhary
Product Support Specialist
New Member
iyer.kool
Message 3 of 9 (6,976 Views)
03-07-2011 09:29 PM in reply to: iyer.kool
Hi Anil
Thank you very much for the steps that you suggested to set the biped dlc error right.  By renaming the Biped.Ini file, the problem was resolved and I am now able to use 3Ds Max 2010.  Thanks again.
Regards
Rahul
New Member
markus_funkus
Message 4 of 9 (6,377 Views)
08-20-2011 08:08 AM in reply to: anil.choudhary
I am having a very similar problem.
When I try to load 3ds max, it will begin opening plug-ins but get hung up on HSDS.dlm.
Can I use this same method to fix the problem?
Product Support
anil.choudhary
Message 5 of 9 (6,362 Views)
08-22-2011 02:27 AM in reply to: markus_funkus
Hello Markus,
Try renaming the HSDS.dlm to hsdsdlm_old and see if that helps. You can also copy the hsds.dlm from another working machine and see if that works.
Cheers
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Anil Choudhary
New Member
markus_funkus
Message 6 of 9 (6,336 Views)
08-24-2011 05:20 PM in reply to: anil.choudhary
Thank you very much! Worked perfectly.
Product Support
anil.choudhary
Message 7 of 9 (6,331 Views)
08-24-2011 05:22 PM in reply to: markus_funkus
Awsome.
Cheers.
Anil Choudhary
New Member
marwanalabhar.web
Message 8 of 9 (6,039 Views)
11-01-2011 05:50 AM in reply to: anil.choudhary
thanks .....solved the error :smileyhappy:)
New Member
femin
Message 9 of 9 (4,325 Views)
12-30-2012 09:00 PM in reply to: iyer.kool
 3ds Max 2010 fails to start due to biped dlc error  .there is no boiped .ini. file in that.please help me :smileysad:
