Installation & Licensing
3ds 2012 give these errors upon startup on win7-64?
4 REPLIES 4
MayaWannabe
1846 Views, 4 Replies
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/base.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: base.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/contour.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: contour.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/physics.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: physics.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/lume.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: lume.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/subsurface.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: subsurface.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/3dsmaxshaders.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: 3dsmaxshaders.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/3dsmaxhair.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: 3dsmaxhair.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/paint.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: paint.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/architectural.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: architectural.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/production.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: production.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/adskshaders.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: adskshaders.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/mr_prebuilt.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: mr_prebuilt.dll
LINK 0.0  error  191007: cannot load .\shaders_standard\mentalray\shaders/SubstanceShader.dll, The specified module could not be found.
LINK 0.0  error  191012: Unable to load file: SubstanceShader.dll
4 REPLIES 4
DarrenP
in reply to: MayaWannabe
try reinstalling the software
it doesn't look like the software was installed correctly
DarrenP
MayaWannabe
in reply to: DarrenP
Re-installing does not fix it. I have had the EXACT same problem with 3ds 2011. I know what the problem is, but I don't know how to fix it. for this error: ----------------- LINK 0.0 error 191007: cannot load .\shaders_standard\mentalray\shaders/base.dll, The specified module could not be found. LINK 0.0 error 191012: Unable to load file: base.dll The file does exist here: C:\Program Files\Autodesk\3ds Max 2012\mentalimages\shaders_standard\mentalray\shaders\base.dll But 3ds 2012 doesn't know to look there. I used the default install on Win7-64. How can I tell 3ds where to look for these dlls, which look like they are installed in the correct place that 3ds wanted to put them? Thanks!
MayaWannabe
Ahhh, I had  Lithium blocked by NoScript, so all the text got jumbled together.  This should be easier to read:
I also have had the EXACT same problem with 3ds 2011.
I know what the problem is, but I don't know how to fix it (except by copying dlls by hand, which is not ideal).
for this error (the other errors were just like this):
But 3ds 2012 doesn't know to look in its own folder for some reason?
Thanks!
Gelashvili
Hi bro! I have a awesome solution for your problem,I have made a tutorial on how to solve the same problem :
http://www.youtube.com/watch?v=Yutx0MGNlPg&feature=youtu.be
Smiley HappySmiley Very Happy
Administrator Productivity
