Please Help! I am receiving this error when running AutoCAD 2012 - 'You are attempting to use a 32bit installer on a 64 bit operating system. Please exit and use the 64 bit installer available from your installation media or available from Autodesk.com’ I have a networking license.
Hi and welcome to the forums!
In case you are not able to locate the 64-bit installer on your AutoCAD media, please download the 64-bit version from the link below:
Best regards,
Hi!
I have the same problem, but would need a french version of Autocad 2012.
Thanks very much in advance
A. Muller
Hi muller and welcome to the forums!
Here's your link:
Best regards,
Hi Camilo,
May I download AutoCAD 2015 64bit? Cause I have same problem in this case.. Many thanks
I need the 64 bit installer for my autocad 2012. The link that you posted no longer works. I also tried 1. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Des... but it only list as far back as 2013.
