Installation & Licensing
Active Member
chris.chan
Message 1 of 24 (165,713 Views)
32bit AutoCAD on 64bit Windows 7 system
165713 Views, 23 Replies
05-25-2010 05:02 AM
can i install autocad 2010or 2011 32bit on window 7 64bit system?
No, not natively. What you can do is install a Windows XP Virtual PC from Microsoft. It comes free for Windows 7 users. That will allow you to run Windows XP from within Windows 7. That's probably your only choice for that PC.
TravisNave
Message 2 of 24 (165,712 Views)
Re: 32bit AutoCAD on 64bit Windows 7 system
05-25-2010 09:13 AM in reply to: chris.chan
No. You will need to install the 64-bit version. The disc media will have both versions and the appropriate one will install. If you downloaded your installation, then you will need to also download the 64-bit version as well.
Active Member
chris.chan
Message 3 of 24 (165,712 Views)
05-25-2010 09:33 AM in reply to: chris.chan
Thanks for your reply,
Is there any way I can install Autocad 2011 32bit on my new system Window 7 64bit, because I have a bolt on software which runs on Autocad, and the bolt on software only runs on Autocad 2011 32bit.
TravisNave
Message 4 of 24 (165,714 Views)
05-25-2010 09:41 AM in reply to: chris.chan
Active Member
chris.chan
Message 5 of 24 (165,712 Views)
05-25-2010 09:55 AM in reply to: chris.chan
would the virtual PC with XP running Autocad be slow?
TravisNave
Message 6 of 24 (165,710 Views)
05-25-2010 10:37 AM in reply to: chris.chan
Depends on your system, I suppose. Won't know until you try.
*BigBill
Message 7 of 24 (165,712 Views)
05-26-2010 04:46 PM in reply to: chris.chan
I am researching the same issue, add on customization requires 32 bit....
I am finding it "might" be possible to install in 32 bit compatibility
mode...
Not sure yet on that, or even how to do.. something to do with WOW64 mode
XP Pro
Intel Core2 Duo
p8400 @2.26 GHz
2.99GB Ram
GeForce 9800M GTS video card
wrote in message news:6397052@discussion.autodesk.com...
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 5148 (20100526) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5148 (20100526) __________
http://www.eset.com
New Member
Mortoyz
Message 8 of 24 (165,313 Views)
Re: Bit AutoCAD on 64bit Windows 7 system
08-16-2010 05:12 PM in reply to: *BigBill
Hi.
I was wondering if there has been any further update / developments to this initial question ?
We are soon to be in a similar problem where out native OS will be Windows 7 running in 64Bit and require Autocad 2010 to run in 32Bit mode to be able to support other applications which only run in 32Bit mode (at this stage).
I am hoping someone on this forum may have a solution / work around to this problem which seems likely to become more of common issue.
Thanks. :smileyhappy:
Marcis
Marese
Message 9 of 24 (164,972 Views)
08-27-2010 01:14 AM in reply to: chris.chan
Same problem here. Anyone found other solutions? If that Longbow Converter can make it work, why is AutoDesk itself not making it easier for us right now. I know the solution should be coming from my plug-in seller but then again... they don't/can't.
They do have another new program that substitutes the program we are still working with but we would need to change our entire environment for that... and it will cost a lot of money. (Almost?) impossible at the moment!
Can't AutoCAD make the version work 32-bits on a 64-bits windows 7 machine for the time being? Why don't they do that?
I think installing a virtual windows xp pc, buying another program to convert AutoCAD and that sort of solutions are not the solving of the problem I seek. They are all work-arounds for a problem that perhaps could be solved easily by AutoDesk itself?
Member
WTLucas
Message 10 of 24 (123,312 Views)
03-28-2011 05:50 AM in reply to: Marese
i'm looking at that software but, i feel Autodesk should have an answer for this matter.  I will typically being running in 64 bit mode but, will only need the 32 bit when doing FlexCad isometrics.  Would be an easy fix if FlexCad would run in 64 bit.  I don't want to burn 2 autocad license on each machine if i don't have to.  The cost is too high for this solution.  There should be an easy fix for this.
Todd
