Installation & Licensing
32bit AutoCAD Map 3D trial
1 REPLY 1
dweber8
1051 Views, 1 Reply
I'm trying to download a trial version of AutoCAD Map 3D for my 32bit system. There appears to only be a 64bit version through the trial download but I see references to a 32bit version in the system requirements documentation. Also looking at the included suites there does not appear to be a 32bit either.
Any help in where I can access 3D map 32bit trial or Civil, I'm most interested in trying out the seamless shapefile export from CAD files.
Thanks!
1 REPLY 1
DarrenP
in reply to: dweber8
for civil 3d 2014 there is no 32 bit version
for map 3d 2014 32 bit you can download from here:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links> Autocad Products> Autocad Map 3D
Please accept as a solution if this fully resolves the issue
DarrenP
Administrator Productivity
