I'm trying to download a trial version of AutoCAD Map 3D for my 32bit system. There appears to only be a 64bit version through the trial download but I see references to a 32bit version in the system requirements documentation. Also looking at the included suites there does not appear to be a 32bit either.
Any help in where I can access 3D map 32bit trial or Civil, I'm most interested in trying out the seamless shapefile export from CAD files.
Thanks!
Solved by DarrenP. Go to Solution.
for civil 3d 2014 there is no 32 bit version
for map 3d 2014 32 bit you can download from here:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links> Autocad Products> Autocad Map 3D
Please accept as a solution if this fully resolves the issue
DarrenP
