Currently I have a bunch of computers with Autocad 2013/2014 32-bit installed, the computers are being upgraded to 64-bit systems. Will I be able to download, install, and activate Autocad 2013/2014 64-bit with the same keys, or will I have to rebuy all the software in 64-bit versions if that is what I want.
Solved by DarrenP. Go to Solution.
autodesk doesn't sell the 32 bit and 64 bit separately
the serial numbers are tied to a product and version (ex: Autocad 2014)
so yes its the same serial number and product key
DarrenP
Thanks a lot!
Do you know where I can download the files to install the progam again? I have my licence keys and all that but cant seem to find the software. I remember downloading them off the website but can't find them now.
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Autocad Products>Autocad
Please accept as a solution if this fully resolves the issue
DarrenP
