Only Autodesk issues updates to software that fail. Unbelievable. I don't use Formit, no idea what it is. Hopefully I'll have to update the software to install the update. That sounds fantastic.
Does anyone know how to fix this? Please see screenshots.
Thanks.
Solved by jcortelyou. Go to Solution.
Hi @jcortelyou
Thanks a lot for posting your question to the forums! Please see below for possible causes and solutions.
Error Context: 1: LicensingCustomAction.licRegister [I] [07:29:02:686]: [NIWSELECTION]: 1: LicensingCustomAction.licRegister [I] [07:29:02:687]: [ADLM_EULA_COUNTRY]: US 1: LicensingCustomAction.licRegister [I] [07:29:02:687]: [ACADLICENSESERVERTYPE]: 1: LicensingCustomAction.licRegister [I] [07:29:02:687]: [CONSUMER]: 1: LicensingCustomAction.licRegister [I] [07:29:02:688]: Running "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\12.0.0.6529\helper\AdskLicensingInstHelper.exe" register --upgrade -pk 829O1 -pv 2023.0.0.F -cf "C:\Autodesk\Revit_2023_r1_G1_Win_64bit_dlm\x64\RVT\RevitConfig.pit" -el US -sn 000-00000000 -sk 829O1 1: LicensingCustomAction.licRegister [E] [07:29:02:941]: exit code: 225, output: Error (25) for adlmPITSetProductInformation_2: Error has occurred while parsing PIT file. Action ended Return value 3 1: LicensingCustomAction.licRegister [E] [07:29:02:941]: Registering a product with key 829O1 and version 2023.0.0.F failed CustomAction licRegister.8B858D99_2C63_4281_AE43_6782314CCC1B returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox) MSI (s) (D0:EC) [07:29:02:957]: Note: 1: 2265 2: 3: -2147287035 MSI (s) (D0:EC) [07:29:02:958]: User policy value 'DisableRollback' is 0 MSI (s) (D0:EC) [07:29:02:958]: Machine policy value 'DisableRollback' is 0 Action ended 7:29:02: InstallFinalize. Return value 3.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
There are still major issues going on here - None of the first 4 solutions worked. Microsoft tool did see 2 Generative Design applications and removed them both when trying to remove one of them. There are a bunch of autodesk products installed so renaming the pit file was not an option. All paths are local and are not cloud based.
The new install package downloaded and installed but Yet Again gave an error for Formit only this time it was at 76% AND 96%. At the 96% Marker the progress bar switches from "Installing Revit" to "Updating Revit". I did a windows explorer search for "FormIt360Converter.msi" and it provided the results in attachment 2. When browsing to the path from windows search via "Open File Location" via windows right click the files is present however it does not appear when browsing from the missing file prompt. The installer says that Revit is ready to use and when it ends another error message occurs referencing Revit Schemas.
I am going to uninstall and reg repair again with another software and manually gut all Revit 2024 References. I will note that this is absolutely ridiculous - unbelievable.
The solution was to Uninstall Revit, Uninstall Form-It, Windows Search for "Revit 2024" References - Delete them all. Reg Repair using CCleaner, Use the Microsoft Uninstall Tool - Formit Converter was listed even after main formit uninstall, uninstall that using MS tool. Reinstall new Revit 2024 Download package. Installs Error Free. "A Three Hour Tour" - Literally.
Wow! Thanks for sharing.
Too bad you didn't try my solution - that would possibly have saved you a lot of work...
