I have been installing updates to my Autodesk products and have encountered a problem. I believe I may have installed my service packs for FabCADmep out of order and installed SP5 first. Ever since I have installed this, I cannot get FabCADmep to open with the desktop icon nor through the start menu. I can still get in to it via regular AutoCAD, but I would like for this to work the way it is supposed to.
Any ideas/help?
@Anonymous
Welcome to the community...
Service Pack 5? I only see Service Pack 2 (or am I missing something?)..
When it launches, what happens? Does it hang on the splash screen? If it does, what does it say in the lower left hand corner of the splash screen?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hey Mark....... Thanks for the reply. You'll have to bear with me........ I'm a novice at all of this stuff.
When I start it from the icon or the all apps portion of the start menu, it will load up to the point of asking for the database. Once I select a database it immediately closes.
I had had no problem until I started installing the updates, which has me a little puzzled. I did have it work one time after a system restart, but that hasn't happened again.
Troy
Hello @Anonymous
Welcome to the community. Sorry for the inconvenience. I would uninstall the current Service Packs you have downloaded and installed, then download and install them back in order.
The following service packs are available for Fabrication CADmep 2016, it appears there is no SP5.
Please keep us posted on your progress. Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
@Anonymous
Ok.. These are not actual service packs.. They are enhancements that people can apply if they have an active subscription. That's why I was confused and asking when I only saw service pack 2. I'm not a user/expert on this application but if you applied enhancement #5 you get all the enhancements 1-4. So you didn't apply anything out of order.
In addition you may have to migrate your database but only guessing at this point. So I would recommend that you actually post over in the application's related forum and see if the actual users of the product can assist you.
Mark Lancaster
Ok........ I will try over there.
My version of FabCADmep is old enough that it is a perpetual license and not a subscription........... maybe I should go back to plumbing.........lol
Hello @Anonymous,
Sorry for the confusion, SP5 is available via your Autodesk account or the Desktop App. You can try to remove the update or try to uninstall the product and re-install it and apply the SP5 to Fab CADmep 2016.
Remove the Update
OR
Reinstall
Please keep us posted.
Natasha
Helpful Links:
Natasha:
I'm in the middle of doing this very thing.
I'm hoping to have this completed sometime today, I'll post results.
Thank you.
