Installation & Licensing
2015 problems in installation
7 REPLIES 7
Message 1 of 8
joshua.ibanez
551 Views, 7 Replies
hi, i tried several times but i can't seem to pass after 840+ mb downloaded, please see attached picture for more clarification on my problem. thank you
7 REPLIES 7
Message 2 of 8
Hi @joshua.ibanez and welcome to the Autodesk Community:)
Please, disable your firewall and anti-virus programs and download AutoCAD LT directly from our Virtual Agent linked here (click on Download Links, select product and version).
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Camilo Lemos
Message 3 of 8
is this same as browser dowload where there are 2 files downloaded? and can i use them to install on a multiple pc? thank you
Message 4 of 8
Yes and Yes:)
You're welcome!
Camilo Lemos
Message 5 of 8
by the way sir, im quite confussed with the download, there are two files right, one 1.12gb and the other 3.93gb so more or less it would be 5.07 gb, i saw the total download file ranging from 11.2 gb, what happen there sir? if i download the two files are there additional files i have to download or what difference does it have versus the 11.2 gb download? thank you
Message 6 of 8
There are no additional files to be downloaded. The difference in size is due to different download methods and their installation requirements and processes. If you download and extract the two files you see on the Virtual Agent you should be good to go.
Camilo Lemos
Message 7 of 8
wow, thanks alot for answering my queries
Message 8 of 8
You're welcome!
Camilo Lemos
Administrator Productivity
