After having some trouble to install Revit 2014 & AutoCAD 2014, i contacted my service provider and they managed to get it to start the install properly. After haging up, i restarted my computer and then tryed to start Revit. It looked like it was going to work but then crash with the option to send the error report to Autodesk, which i have. It did not load any main screen or anything of the like.
If anyone can help with this that would be great.
Let me know if you would like some more information.
Cheers,
Dan
Hi Dan,
Could you check the link below if this is the same as the issue you are having and try out the suggestions provided there? Let us know how it goes. Thanks.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22165868&linkID=21208796
Best Regards,
