I am using a Windows 8 Acer 11" slate. I have downloaded Inventor 2014, Autocad 2014 and Revit 2014 using browser download. When I go to install these programs the Autodesk Auto Extractor opens and starts to extract the file. At 490mb extracted the extractor stops and does not change or respond. I have tried into both my C: drive and into my documents incase the laptop is restricted by the education department to install the program in C: drive. Nothing works. Is this a problem with restrictions on the computer or with the program?
It might simply be a corrupted download. It happens. You should try downloading the file again and see if you have better luck.
I have also used the installers on my own laptop with Widnows 7 and they work fine. I am guessing that there are certain restrictions on my school compter that will not allow the programs to install.
