Installation & Licensing
8 Kudos
Post 1 of 3
2014 network deployment missing ability to remove 'Password' option
215 Views, 2 Replies
03-04-2014 10:56 AM
In previous releases, in the network deployment, I could disable the 'Password Protection' feature for DWG files (that appears in Options dialog box). I cannot find where to disable that now. I do not want my users to be able to password protect a drawing. I also do not want to individually modify the 100 PCs that will be receiving AutoCAD.
This is AutoCAD MEP 2014 as part of the BDS Premium Suite.
Dustin
Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
You can build a deployment. From the Create Deployment>Configure deployment screen, expand the twisty to configure. Select the option 'custom'.  Remove the check from 'Drawing Encryption'. For more details please refer to the link:
Disable password protection
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Disable-password-protection.html
Product Support
10 Kudos
Post 2 of 3
Re: 2014 network deployment missing ability to remove 'Password' option
03-05-2014 08:53 AM in reply to: dtiemeyer
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Disable...
BHurley
Product Support
115 Kudos
Post 3 of 3
03-06-2014 08:11 AM in reply to: brad.hurley
I was interested in the post and you (Brad) beat me to it!!!  I have included some screen captures of the install and deployement process of disabling this feature via the Control Panel.
David Lau
