I created a deployment and saved it on a location on the server that is shared. Next, I needed to modify the deployment to add a service pack that was added. I logged into the server where the deployment was using a Remote Terminal at my workstation. After I modified the deployment, it lists my workstation as the location that the deployment should be ran from. This location is not shared and I would like it to be ran from the original locaton on server.
Is there a way to make it place the modified deployment in the same location as the original deployment?
Here is what I see after the deployment is modified.
Kirk
Solved by asburyj. Go to Solution.
Did you create the deployment on one server and then copy it to a new server or did perhaps the servername change? It appears that the original server location was KARTHUR-7 so if that is changed you will want to recreate your deployment.
I orginally created the deployment on the fmi2 server (using remote desktop from karthur workstation). The server name has never been changed nor has the deployment been copied.
Perhaps the incorrect location was entered when creating it? I would suggest recreating the deployment at this point
Your other option would be manually editing though the ini file for the deployment and manually changing the target for the links but my recomendation if just for recreation since you are needing to add in a service pack anyway.
