Installation & Licensing
2014 Deployment - Can't select Customization setttings
5 REPLIES 5
karthur1
391 Views, 5 Replies
In my deployment, I wanted to use a custom setting for my application options.  When I browse to the location of the .xml file, no files are shown in the dialog. When I browse to the location with Windows Explorer, the files are there.
(See Attachment)
I tried moving the files to a local drive, but that did not help.
5 REPLIES 5
DarrenP
in reply to: karthur1
thats a wierd one
i will try to reproduce here
DarrenP
DarrenP
in reply to: DarrenP
it works for ultimate
i will have to download premium suite to see if thats the issue
DarrenP
karthur1
I am using the APDS Premium.
TravisNave
I also answered here:
http://forums.autodesk.com/t5/Installation-Licensing/2014-Deployment-Cant-select-file-under-configur...
It's possible that you have found a bug.  Keep us posted.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
karthur1
No idea why it works now.  I went back and used the "Create & Modify a Deployment".  I can now select the .xml file I want to use.  Same steps as I used before.
Thanks.
Administrator Productivity
