Installation & Licensing
*Expert Elite*
Joe-Bouza
Message 1 of 7 (233 Views)
2013 raster secondary installer
233 Views, 6 Replies
02-07-2013 01:05 PM
I recently deployed 2013 IDSP and everytime I start civil3d the raster secondary installer runs. Is that a problem? can it be fixed?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Expert Elite*
dgorsman
Message 2 of 7 (225 Views)
Re: 2013 raster secondary installer
02-07-2013 02:30 PM in reply to: Joe-Bouza
Usually that means registry and/or local user file settings made by the secondary installer are not being kept, and usually thats a rights issue.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
*Expert Elite*
Joe-Bouza
Message 3 of 7 (217 Views)
02-09-2013 07:04 AM in reply to: dgorsman
Hmm. each user at each work station has admin rights.?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
TravisNave
Message 4 of 7 (201 Views)
02-11-2013 08:24 AM in reply to: Joe-Bouza
Have any of the user's profile settings been moved from default location elsewhere, like on a server?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
*Expert Elite*
Joe-Bouza
Message 5 of 7 (198 Views)
02-11-2013 08:26 AM in reply to: TravisNave
I would have to check with IT but I doubt anything changed
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
dgorsman
Message 6 of 7 (184 Views)
02-12-2013 11:20 AM in reply to: Joe-Bouza
Yes - at least, enough to allow modification of the appropriate registry entries.  We have a number of different programs which run with local data files and stores some additional information in the registry.  Locking things down would prevent the software from running properly.
For Raster Design, you might get away with a power/admin user starting the program and getting the secondary installer to run properly before letting a restricted user.  Probably a good idea to check the registry before, during, and after running to see if things are getting added where necessary.
Product Support
byron.morales
Message 7 of 7 (170 Views)
02-14-2013 08:58 AM in reply to: Joe-Bouza
Hello All:
This issue was similar to:
http://upandready.typepad.com/up_and_ready/2012/04/raster-design-2013-missing-commands-iinsert.html
We resolved the issue with Joe as follows:
We cheked the registry entry:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19\AutoCAD Raster Design 2013
There Raster 2013 was associated with Map 3D but the program had not being opened yet, therefore the program folder had not been created yet and Raster kept trying to write there.
We Opened Map 3D and it created the program folders and now Raster's Secondary Installer does not appear anymore.
In Short Please launch all 3 AutoCAD verticals (AutoCAD, Civil 3D and Map 3D) and then Raster will not run the secondary installer.
Byron Morales
Announcements
Need installation help?
