Installation & Licensing
2013 Product Design Suite Ultimate Media and Product Design Suite Premium?
4 REPLIES 4
RayNeudorf
696 Views, 4 Replies
We have two standalone licenses at work.
One is Product Design Suite Ultimate
One is Product Design Suite Premium
I received a thumb drive for Product Design Suite Ultimate, but not one for Product Design Suite Premium.
Can I install Product Design Suite Premium from the Product Design Suite Ultimate thumb drive?
Thanks!
4 REPLIES 4
TravisNave
in reply to: RayNeudorf
Yes, just use the correct serial number and product key and you will be fine.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
RayNeudorf
in reply to: TravisNave
Thanks!
royden.chick
I saw the proposed solution and I wanted to know if you were able to successfully install PrDS-Premium from the Ultimate media? What issues did you encounter? Did you finally recieve the PrDS Premium media?
-Roy
Roy Chick
QA - DLS Release Manager
Autodesk, Inc.
TravisNave
in reply to: royden.chick
So long as you have the Ultimate media, you should have absolutely no issues installing the Premium content with the correct serial number and product code.  This is by design.
Autodesk Forums:
Administrator Productivity
