We have two standalone licenses at work.
One is Product Design Suite Ultimate
One is Product Design Suite Premium
I received a thumb drive for Product Design Suite Ultimate, but not one for Product Design Suite Premium.
Can I install Product Design Suite Premium from the Product Design Suite Ultimate thumb drive?
Thanks!
Solved by TravisNave. Go to Solution.
Yes, just use the correct serial number and product key and you will be fine.
I saw the proposed solution and I wanted to know if you were able to successfully install PrDS-Premium from the Ultimate media? What issues did you encounter? Did you finally recieve the PrDS Premium media?
-Roy
So long as you have the Ultimate media, you should have absolutely no issues installing the Premium content with the correct serial number and product code. This is by design.
