Installation & Licensing
2012 installation problem
2 REPLIES 2
adeeb
3754 Views, 2 Replies
2011/6/8:12:06:27 admin_SitiAzah WMY-SA-077 === Setup started on WMY-SA-077 by admin_SitiAzah ===
2011/6/8:12:06:27 admin_SitiAzah WMY-SA-077 Launch
2011/6/8:12:07:36 admin_SitiAzah WMY-SA-077 === Setup ended ===
2011/6/8:12:06:34 admin_SitiAzah WMY-SA-077 === Setup started on WMY-SA-077 by admin_SitiAzah ===
2011/6/8:12:06:34 admin_SitiAzah WMY-SA-077 Launch
2011/6/8:12:07:36 admin_SitiAzah WMY-SA-077 PageOpen LaunchDialog
2011/6/8:12:07:56 admin_SitiAzah WMY-SA-077 PageOpen LicenseDialog
2011/6/8:12:08:04 admin_SitiAzah WMY-SA-077 PageOpen ProductInfoDialog
2011/6/8:12:10:45 admin_SitiAzah WMY-SA-077 PageOpen ProductSelectionDialog2
2011/6/8:12:11:04 admin_SitiAzah WMY-SA-077 PageOpen FullProgressDialog
2011/6/8:12:11:04 admin_SitiAzah WMY-SA-077 Installing .NET Framework Runtime 4.0: D:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2011/6/8:12:17:43 admin_SitiAzah WMY-SA-077 Install .NET Framework Runtime 4.0 Succeeded
2011/6/8:12:17:43 admin_SitiAzah WMY-SA-077 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2011/6/8:12:17:54 admin_SitiAzah WMY-SA-077 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2011/6/8:12:17:54 admin_SitiAzah WMY-SA-077 Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2011/6/8:12:18:29 admin_SitiAzah WMY-SA-077 Install DirectX Runtime Succeeded
2011/6/8:12:18:29 admin_SitiAzah WMY-SA-077 Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/6/8:12:18:50 admin_SitiAzah WMY-SA-077 Install FaroSDK Succeeded
2011/6/8:12:18:51 admin_SitiAzah WMY-SA-077 Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\DOCUME~1\ADMIN_~2\LOCALS~1\Temp\_AI130.tmp\Media.mst"
 2011/6/8:12:19:44 admin_SitiAzah WMY-SA-077 Install Autodesk Material Library 2012 Succeeded
2011/6/8:12:19:44 admin_SitiAzah WMY-SA-077 Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\DOCUME~1\ADMIN_~2\LOCALS~1\Temp\_AI130.tmp\Media.mst"
 2011/6/8:12:21:54 admin_SitiAzah WMY-SA-077 Install Autodesk Material Library 2012 - Low Resolution Succeeded
2011/6/8:12:21:54 admin_SitiAzah WMY-SA-077 Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/6/8:12:22:30 admin_SitiAzah WMY-SA-077 Install Autodesk Content Service Succeeded
2011/6/8:12:22:32 admin_SitiAzah WMY-SA-077 Installing AutoCAD® 2012:  TRANSFORMS="D:\x86\en-us\acad\acad.mst;C:\DOCUME~1\ADMIN_~2\LOCALS~1\Temp\_AI130.tmp\x86\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/6/8:12:31:41 admin_SitiAzah WMY-SA-077 Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2011/6/8:12:32:42 admin_SitiAzah WMY-SA-077 Rollback Autodesk Content Service Succeeded
2011/6/8:12:34:08 admin_SitiAzah WMY-SA-077 Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2011/6/8:12:36:30 admin_SitiAzah WMY-SA-077 Rollback Autodesk Material Library 2012 Succeeded
2011/6/8:12:36:33 admin_SitiAzah WMY-SA-077 Rollback FaroSDK Succeeded
2011/6/8:12:36:33 admin_SitiAzah WMY-SA-077 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2011/6/8:12:36:33 admin_SitiAzah WMY-SA-077 Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
hi there,
i try to install revit architecture 2012 at widows xp using dvd from auttodesk and it fail  please check my log file.
thanks
Adeeb
2 REPLIES 2
TravisNave
in reply to: adeeb
There should be a more detailed log file in your %temp% location of the failure.
You might try copying the DVD to your HDD and installing locally from there.  As always, be sure to have Admin rights and your anti-virus disabled.
Autodesk Forums:
醒呀醒
in reply to: TravisNave
2013/3/9:00:32:49 Administrator HEZILI Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="D:\Autodesk\Autodesk_Revit_Architecture_2012_CHS_Win_32-64bit\x64\zh-cn\RAC2012\RAC2012.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AI10DE.tmp\x64\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_Architecture_2012_CHS_Win_32-64bit\" INSTALLDIR="D:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/9:00:46:44 Administrator HEZILI Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
Administrator Productivity
