Installation & Licensing
2011 autocad lt from 32 bit to 64 bit
19 REPLIES 19
Message 1 of 20
carrielawson
2961 Views, 19 Replies
I recently received a new PC with Windows 7 64 bit and I am trying to transfer my license and autocad to the new computer.  I already did the export license.  When i try to install autocad lt 2011 from the disc I had it gives me an error that this version will not work on my new computer.  Is this a 32 bit Windows 7 previous to now a new 64 bit Windows 7 issue?  If so, is there a download link for the 64 bit version so that I can install that and then transfer my license?   THANKS so much!
19 REPLIES 19
Message 2 of 20
philip.s
in reply to: carrielawson
carrielawson - here's a 24hr timed direct download link for the 64BIt software.
AutoCAD LT 2011 - 64BIT - LINK
Message 3 of 20
carrielawson
in reply to: philip.s
thank you Phillip,  the link and activation worked.
Message 4 of 20
bpesys
I am having the same issue with Autocad LT 2012, could you give me a link to download the 64 bit software? Thanks.
Message 5 of 20
philip.s
in reply to: bpesys
Here you go bpesys!
AutoCAD LT 2012 - 64 BIT - LINK
Please not that for future reference you can also request replacement media and or previous version download links (if available) directly via this link.
Message 6 of 20
jd.barnidge
I'm having the same issue with a new Windows 7 64bit computer. Have a license/package for Windows 7 32 bit. Need the 64bit downloadable version.
Thanks.
Message 7 of 20
philip.s
in reply to: jd.barnidge
Hi JD,
Most current + supported previous version software titles can be accessed via Matt, our Virtual Assistant.
Message 8 of 20
LarsonData01
About a year and half I transferred my license from a 32bit to a 64 bit and now I am moving to a new pc again. Do I need the download for the 2011 autocad LT 64 bit to get it to work on my new pc running windows 7 64 bit.
Message 9 of 20
pendean
in reply to: LarsonData01
Did you save the original 64bit download file? Then you can use it.
If not (not sure why not), you can grab antoher copy, and this time actually save it somewhere save:
1. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
2. Select the choice "Download Links".
3. Select your product, then variant, then version as applicable.
4. You should now be presented with the choice to download your software.
Message 10 of 20
LarsonData01
in reply to: pendean
I am not sure why but after I install Autcad LT 2011 and try to run the
program it restarts the installation process over again. I have tried
running the program from both the icon on the desktop and the start menu,
restarting the pc, and running the installation fresh as an administrator.
what could I be missing that would cause it to rerun the installation?
Message 11 of 20
pendean
Is it relaunching the install process, or just "initializing" for a first run?
Message 12 of 20
LarsonData01
It is initializing but I cannot get past the screen when it asks for my
Serial Number and product key.
I get a message saying "pit.config is not found!"
Suggestions?
Josh Rasmussen
Larson Data Communications
PO Box 96, 220 S. Kimball
Mitchell, SD 57301
Toll Free (866) 996-5521
Ofc. Ph. (605) 996-5521
Fax (605) 996-5642
E-mail: joshua.rasmussen@larsondata.com
Message 13 of 20
pendean
Searching around here were you are posting revealed many solutions, including this one: http://forums.autodesk.com/t5/Installation-Licensing/pit-config-is-not-found-Windows-Autocad-LT-2011...
Message 14 of 20
LarsonData01
Thanks that solved my issues.
I appreciate the help
Josh Rasmussen
Message 15 of 20
kbrzychcy
Any chance of getting an Autocad 2011 LT 64-bit download link?
Thanks in advance.
Kris
Message 16 of 20
camilo.lemos
in reply to: kbrzychcy
Hi Kris!
Sure thing! Here are the links for AutoCAD LT 2011 - both the 64 and 32-bit versions:
AutoCAD LT 2011 32-bit
AutoCAD LT 2011 64-bit
Please accept as solution if my post fully resolves your issue.
Camilo Lemos
Message 17 of 20
kbrzychcy
in reply to: camilo.lemos
Thanks for the fast reply.
Much appreciated.
Message 18 of 20
camilo.lemos
You're welcome!
Camilo Lemos
Message 19 of 20
anna.ch
I am also getting a new PC with Windows 7 64bit and I want to transfer my AutoCAD LT 2008 licence from the old computer (32bit) to the new one. Is there a download link for 64bit? I would really appreciate your help. Thank you in advance.
Message 20 of 20
anna.ch
in reply to: anna.ch
The problem is solved.
Administrator Productivity
