I recently received a new PC with Windows 7 64 bit and I am trying to transfer my license and autocad to the new computer. I already did the export license. When i try to install autocad lt 2011 from the disc I had it gives me an error that this version will not work on my new computer. Is this a 32 bit Windows 7 previous to now a new 64 bit Windows 7 issue? If so, is there a download link for the 64 bit version so that I can install that and then transfer my license? THANKS so much!
Solved by philip.s. Go to Solution.
carrielawson - here's a 24hr timed direct download link for the 64BIt software.
AutoCAD LT 2011 - 64BIT - LINK
I am having the same issue with Autocad LT 2012, could you give me a link to download the 64 bit software? Thanks.
Here you go bpesys!
AutoCAD LT 2012 - 64 BIT - LINK
Please not that for future reference you can also request replacement media and or previous version download links (if available) directly via this link.
I'm having the same issue with a new Windows 7 64bit computer. Have a license/package for Windows 7 32 bit. Need the 64bit downloadable version.
Thanks.
Hi JD,
Most current + supported previous version software titles can be accessed via Matt, our Virtual Assistant.
About a year and half I transferred my license from a 32bit to a 64 bit and now I am moving to a new pc again. Do I need the download for the 2011 autocad LT 64 bit to get it to work on my new pc running windows 7 64 bit.
Did you save the original 64bit download file? Then you can use it.
If not (not sure why not), you can grab antoher copy, and this time actually save it somewhere save:
1. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
2. Select the choice "Download Links".
3. Select your product, then variant, then version as applicable.
4. You should now be presented with the choice to download your software.
Hi Kris!
Sure thing! Here are the links for AutoCAD LT 2011 - both the 64 and 32-bit versions:
Please accept as solution if my post fully resolves your issue.
I am also getting a new PC with Windows 7 64bit and I want to transfer my AutoCAD LT 2008 licence from the old computer (32bit) to the new one. Is there a download link for 64bit? I would really appreciate your help. Thank you in advance.
@anna.ch wrote:Hello,
The problem is solved.
