Hi, i created a document with Autocad 2014 LT and did a "save-as" to a 2007 file for another user using the 2011 version of CAD and it kept crashing, no matter if i saved it as a 2004, 2007 or 2010 version. What's the error below and is this a common error?
Unhandled Access Violation Reading 0x0058 Exception at 78490998h
AutoCAD Alert
AutoCAD cannot continue. You can attempt to save changes
into the following file up to the start of the last command:
C:\Documents and Settings\ENDXL\Local Settings\Temporary Internet Files\Content.Outlook\DTZPSR3D\111160__548_Beatty_St_ R00 (2004)_recover.dwg
Stupid question time: is the DWG file being opened directly from an email? If so, it should be saved somewhere first.
Hi, I have no idea. It's a design i did for a municipal permit, so they deal with CAD all the time. I would assume they save it first but I can't say for sure.
