Installation & Licensing
2009 License Transfer
5 REPLIES 5
RitzCraftPAEng
966 Views, 5 Replies
We had an old PC that had AutoCAD 2009 on it and used the portable license utility to export the license to a thumb drive.  The old PC has since been wiped and is running Linux.  Fast forward to today.  I tried to install AutoCAD 2009 on a new machine using the portable license utility and was told I couldn't do so due to the PCs not being the same.  I have the exported 2009 license but I cannot import it to the new machine and have no access to the old machine.  How do I go about activating AutoCAD on the new machine?
5 REPLIES 5
pendean
in reply to: RitzCraftPAEng
That tool is dead now to you: simply reauthroize 2009 on the new PC like you did on the old PC way back in the day.
Thank you for the response.  I've tried activating the product with two different serial #s and wasn't able to get either to work.  The original said it was invalid and the second let me go through the website but gave an error when I entered the request code.  I reinstalled AutoCAD to try a different serial # and no luck.  Any help would be greatly appreciated.
pendean
Usually, when you get an "invalid" it means that serial number was used for an upgrade.
Also, unless you emailed someone today about a "request code", any old one you may have is no longer relevant, that was tied to your old PC.
If you want to find the correct serial numbers (calid ones), you can contact Autodesk Product Registration and Authorization:
http://usa.autodesk.com/support/installation/
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
Just realize it's Friday afternoon right now.
Yong.Jing
Active the license again is the easiest way. Please go to this link to active online or manually. http://knowledge.autodesk.com/support-topics/483/486
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
We were able to get it activated by reinstalling autocad 2009 on the old hard drive, importing the license, adding the new PC, and exporting the license again.  A royal PITA but at least it worked.  Thank you for your suggestions!
Administrator Productivity
