Installation & Licensing
2 Suites, Same Workstations
5 REPLIES 5
206 Views, 5 Replies
Hi There,
  Can networked installs from two suites co-exist on the same workstation??
ie:  AutoCAD Revit Architecture Suite and Building Design Ultimate Suite
or do i need to leave out the packages (revit & Autocad) from ultimate that already exist from AutoCAD Revit Architecture Suite
5 REPLIES 5
DarrenP
i would just intall both from the building suite
DarrenP
andrew.warren
We do it with Factory Design and Product Design Suites. In my past I did it with Building Design and Infrastructure Design without any problems. I would just use the Ultimate first because it will have more features built in.
Andy Warren
BCDesign@bellsouth.net
thanks guys for your comments, the problem with installing from design suite is that we only have 1 network license and it was purchased primaraly for Navisworks..  We have 5 x of the Architecture suite.
I have this feeling that the navisworks may be required on all of the 5 workstations used only occasionally by all, where revit from the architecture suite will be used all 5 at a time.
TravisNave
Both Navisworks and Revit Arch will pull from Building Design Suites Ultimate.  It's no big deal.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18708338&linkID=9240697
Autodesk Forums:
Thanks Travis for your reply.  I stumbled across the Cascading Licenses from your link shorlty before your post.
thanks for confirming it will work.
Administrator Productivity
