Installation & Licensing
michaelshelley625
246 Views, 2 Replies
2 machines one license
Guys,
I know this question has been asked before, I have looked on some of the threads but can't find what I'm looking for.
My problem is I am the only person in the company who is using AutoCAD 2008 full version. I have a laptop which I use all the time, I am now getting an extra machine for rendering and using when I am in the office. Is there an easy way to transfer the license from one machine to the other and the end of each day? And is there a limit to how often you can do so?
I would really appreciate your help on this!!
regards
Michael Shelley
2 REPLIES 2
in reply to: michaelshelley625
Check you license docs, (EULA). You should be allowed to install it on both
computers like you want without transferring the license back and forth.
John
"michael shelley" wrote in message news:5901729@discussion.autodesk.com...
Guys,
regards
Michael Shelley
Right. A second installation is allowed, given that you do not use both at the same time. Alternately, you can use the PLU to move the license back and forth. Though I would recommend using the 2nd authorization, per the EULA.
Autodesk Forums:
Administrator Productivity
