I had previously started an installation and it worked fine, but I had to cancel the install since my laptop was about to die. When I tried to resume the install later, the installer skipped through everything and said that everything had failed installing. Log file attatched. Also, I previously had Inventor Pro 2014 Installed on this and it worked fine, then I had to factory reset my laptop due to Windows not working right.
I'm using a Student license.
HP 2000 Notebook PC
Intel Core i3-3110M CPU @2.40 GHz 2.40GHz
3.89 GB Usable RAM
Windows 8.1
Intel HD Graphics 4000
ACPI x64 Based PC
If you need more info, just ask.
Looking at the log file your install is failing on the Visual C++ 2012 redistributable.
2014/10/9:16:30:50 Owner ADMIN-PC-3 Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=-2147024546
I would recommend starting with go to Control Panel and Uninstall a Program and remove or uninstall any Microsoft Visual C++ 2012 Redistributable's in the list then reboot and rerun the Inventor install.
Danny
tengo el mismo problema pero no puedo desinstalar uno de los programas visual c++, alguien que me pueda ayudar con una manera para desinstalarlos??
