Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
0.1.0011 Error for AutoCAD 2009 based products
2 REPLIES 2
david.lau
2814 Views, 2 Replies
A support call was recently was logged and there was an error with activating an AutoCAD 2009 based products.   We tried the following TS's but it did not work:
Hotfix - Autodesk Activation Update
http://usa.autodesk.com/getdoc/id=DL5620053
Activation error 0.1.0011 or 11.1.6011 on computers with Serial ATA hard disk controllers
http://usa.autodesk.com/getdoc/id=TS1052460
Upon further investigation, we were able to resolve the issue with this TS:
Activation errors when running program on a machine using external USB devices
http://usa.autodesk.com/getdoc/id=TS1059719
David Lau
Tags (1)
2 REPLIES 2
Batemanah
in reply to: david.lau
Any chance the TS you used to resolve the issue could be found somewhere?
in reply to: Batemanah
No Autodesk stopped providing activation codes for this version
Administrator Productivity
