A valid license could not be obtained by the network license manager error [-5.412.10061]
if you are still unable to access a licence,contact your system administrator
Autodesk simulation cfd 2014
windows 7 x 64
Hello and welcome to the forums.
Please check your network license file. Based on the error you receive it appears that you probably missing a CFD Study Environment 2014 license in your network license file. Please note that for CFD 2014 you need to have each CFD module license encrypted and then combined in your network license file.
Below is the link to the Autodesk TS regarding how to find your CFD serial numbers on your Subscription centre account.
http://usa.autodesk.com/getdoc/id=TS1105767
Once you have your CFD 2014 serial numbers, you can generate your licenses (you need to generate each CFD module license separately) via the link below.
Now you can combine your CFD 2014 licenses and configure your license server with the combined license file.
Please let us know if this helps.
