My computer lab uses Workgroup Manager 10.7.5 to manage our computers. I have enabled Maya to work on the machines, and it does - for the most part.
The problem is when I try to batch render. I get the following error (see pic). I have tried to locate where the Render application is on my mac, but cannot find it. I have enabled a lot of folders associated with Maya and Autodesk, but so far nothing has worked.
If I can locate this application (meaning where it gets installed), I should be able to enable it using our Apple Workgroup. This should fix the problem.
So, my question is, where is this "render application" (that get activated to do batch renders) installed on a Mac 10.7 when doing an install of Maya 2014?
Crystal
