Installation & Licensing
What exactly should I buy?
5 REPLIES 5
AnimatingAmateur
518 Views, 5 Replies
So, I have recently been using Maya on a school computer, but now I am planning to get a new computer that can run Maya. What graphics card, computer type, etc. should I buy? I'm hoping not to spend over 1k since I am infact a bit of an amateur and don't have a large budget to work off of. Thanks y'all!
5 REPLIES 5
a Geforce 760 with 4GB of ram is the perfect card.
Geforce 760 4GB
dgorsman
in reply to: AnimatingAmateur
Its not exactly a light program.  Depending where you are located (a dollar here isn't necessarily a dollar where you are), you'll probably be looking at ~ $1500 for a computer that will do more than the bare minimum simple exercises.  You'll want something with either four or six cores with a decent clock speed (i5 is frequently recommended as best cost/performance blend).  Plenty of RAM, 12 - 16 GB is normal.  You can probably get by with 8 GB but it won't take much to overrun that and RAM is cheap these days.  Don't skimp on hard drive size - its tempting to get a small/cheap solid state drive but almost all application data needs to be on it, not just the operating sytem.  Best cost/performance blend is usually a commonly available mid-size SSD with a large SATA III/large buffer conventional hard drive for data storage.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Here you go this is what I would get.
Qty.
Product DescriptionSavingsTotal Price
1
Intel Core i7-3770 3.4GHz (3.9GHz Turbo) LGA 1155 Desktop Processor
Item #:N82E16819116502
Return Policy: CPU Replacement Only Return Policy
 $299.99
1
G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory
Item #:N82E16820231589
Return Policy: Memory Standard Return Policy
 $189.99
1
EVGA 04G-P4-2768-KR G-SYNC Support GeForce GTX 760 4GB 256-Bit GDDR5 PCI Express 3.0 SLI Support SC 4GB w/ EVGA ACX Cooler Video Card
EVGA G-SYNC Support GeForce GTX 760 04G-P4-2768-KR SC 4GB w/ EVGA ACX Cooler Video Card
Item #:N82E16814130949
Return Policy: VGA Standard Return Policy
 $309.99
Add EVGA G-SYNC Support GeForce GTX 760 04G-P4-2768-KR SC 4GB w/ EVGA ACX Cooler Video Card to cart
1
ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
ASUS P8Z77-V LK ATX Intel Motherboard with UEFI BIOS
Item #:N82E16813131837
Return Policy: Standard Return Policy
 $139.99
$124.99
Add ASUS P8Z77-V LK ATX Intel Motherboard with UEFI BIOS to cart
1
Seagate SV35.6 Series ST1000VX000 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Surveillance Hard Drive Bare Drive
Seagate SV35.6 Series 1TB 3.5" SATA 6.0Gb/s Surveillance Internal Hard Drive -Bare Drive
Item #:N82E16822148912
 $79.99
$64.99
Add Seagate SV35.6 Series 1TB 3.5" SATA 6.0Gb/s Surveillance Internal Hard Drive -Bare Drive to cart
1
SanDisk Ultra Plus SDSSDHP-256G-G25 2.5" MLC Internal Solid State Drive (SSD)
Item #:N82E16820171741
Return Policy: Limited Replacement Only Return Policy
 $199.99
$109.99
1
RAIDMAX Altas ATX-295WBP Black Steel / Plastic ATX Mid Tower Computer Case 500W Power Supply
RAIDMAX Altas ATX-295WBP Black Computer Case With Side Panel Window
Item #:N82E16811156258
 $69.99
$59.99
Add RAIDMAX Altas ATX-295WBP Black Computer Case With Side Panel Window to cart
Grand Total:$1,159.93
Add all to cart
Thanks for the list of items, but what computer should I use with the stuff? Also, are there any good and recommendable computers that has one or more of the items on the list pre-installed?
Dimind
That stuff is a computer.  You buy those, then put it together.
Administrator Productivity
