Anyone here working with a rMBP, Late 2013? I'm having issues...when selecting any object, while my mouse is pressed, the viewport goes black. When I release the button, it is visible again. This only happens in viewport 2.0, and only on the discrete graphics. If I force it to run on the integrated graphics, I don't have this issue.
Is there any way to update the 750m drivers on a MBP? Any suggestions as to what else might be causing this? Thanks!
Exactly the same problem started on my MacBook Pro Retina just after I had updated Mavericks to version 10.9.3.
Karl
So, I found a rather obscure way to prevent this issue and it has worked for me every time. When you first open up Maya, wait for everything to load, then marquee select inside the viewport (2.0 by default). The scene is empty, but make a few marquee selects anyway. Now, when you open your project file, the issue should go away.
