Hi Everyone !
I was trying several times to download Maya 2015 student version - all failed.
I lets me to download the Installation Manager, but once I start the actual download, it crshes seconds after 3rd installment (the actual Maya) , and comes with a messege " failed to download these components"
- has anyone come across this problem? if so - how to solve it?
- would it work to download 30 days trial version and then activate it with the student serial number and product key Autodesk has sent me?
Hi @Anonymous and welcome to the Autodesk Community.
Please, disable your firewall and anti-virus programs and download the software from our Virtual Agent linked here (click on Download Links, choose product and version). You can then use the serial number provided by the Education Community to activate it.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Unfortunatley it didn't work,
I have turned off all the firewall on my computer,
the virtual agent enables me to download the program, hoverver at the end of the download the messege comes up that at least one of the download files either missing or have not been downloaded properly
i have installed Maya 2014 today (after giving up the idea of downloading Maya 2015 after numerous trials) - and did not have any problems at all.
are there any other solutions to this?
Hi @Anonymous,
It really depends. Have you checked the Autodesk Maya system requirements for both versions? You could also pull the installation log file so we could dig a little deeper into the issue. Or you could continue to use the 2015 release
My computer has Intel7 prossesing card, Windows 7 and 8GB RAM. which makes the system more than sufficient to instoll the programm. however after more numerous attemts It failed again... (and turning off the firewall as I was advised by one of Autpodesk reps. really messed up my computer)
I get the immpression that its a bug egsisiting only with Maya 2015, since I have downloaded Maya 2014 without any truble, AND managed to download 3DS Max 2015 and Mudbox 2015 without any truble, and without turning off my Firewall and antivirus setting..
I have seen also from the comments and other posts that there are lots of people who are having this problem with Maya 2015
the file log:
2014/8/28:11:10:32 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:11:10:32 owner OWNER-PC Path_Length: 143
2014/8/28:11:10:32 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:11:10:32 owner OWNER-PC Launch
2014/8/28:11:10:32 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:11:10:32 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI6F94.tmp
2014/8/28:11:10:45 owner OWNER-PC === Setup ended ===
2014/8/28:11:10:33 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:11:10:33 owner OWNER-PC Path_Length: 143
2014/8/28:11:10:33 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI6F94.tmp
2014/8/28:11:10:33 owner OWNER-PC Launch
2014/8/28:11:10:35 owner OWNER-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:11:10:45 owner OWNER-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:11:10:45 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:11:11:10 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:11:11:10 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:11:11:10 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:11:11:29 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:11:11:30 owner OWNER-PC Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:11:11:34 owner OWNER-PC Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:11:11:34 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:11:12:07 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:11:12:07 owner OWNER-PC Download Play VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:11:12:12 owner OWNER-PC Download Complete VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:11:12:12 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:11:12:29 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:11:12:29 owner OWNER-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:11:12:35 owner OWNER-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:11:12:35 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:11:13:03 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:11:13:03 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:11:13:03 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:11:13:04 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:11:13:04 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:11:13:04 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:11:13:04 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:11:14:41 owner OWNER-PC === Setup ended ===
2014/8/28:11:51:35 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:11:51:35 owner OWNER-PC Path_Length: 143
2014/8/28:11:51:35 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:11:51:35 owner OWNER-PC Launch
2014/8/28:11:51:35 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:11:51:35 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI454.tmp
2014/8/28:11:51:37 owner OWNER-PC === Setup ended ===
2014/8/28:11:51:36 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:11:51:37 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:11:51:43 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:11:51:43 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:11:51:43 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:11:52:16 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:11:52:16 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:11:52:16 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:11:52:28 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:11:52:28 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:11:52:28 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:11:52:52 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:11:52:52 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:11:52:52 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:11:53:16 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:11:53:17 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:11:53:17 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:11:53:17 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:11:53:17 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:11:53:18 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:11:53:19 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:11:53:37 owner OWNER-PC === Setup ended ===
2014/8/28:12:49:57 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:12:49:57 owner OWNER-PC Path_Length: 143
2014/8/28:12:49:57 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:12:49:57 owner OWNER-PC Launch
2014/8/28:12:49:57 owner OWNER-PC CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /skipPI /SN 900-37024729 /PK 657G1 /akamai
2014/8/28:12:49:57 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI72B1.tmp
2014/8/28:12:50:01 owner OWNER-PC === Setup ended ===
2014/8/28:12:49:58 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:12:49:58 owner OWNER-PC Path_Length: 143
2014/8/28:12:49:58 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI72B1.tmp
2014/8/28:12:49:58 owner OWNER-PC Launch
2014/8/28:12:49:59 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:12:50:00 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:12:50:05 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:12:50:08 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:12:50:08 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:12:50:13 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:12:50:13 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:12:50:13 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:12:50:20 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:12:50:20 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:12:50:20 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:12:50:40 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:12:50:40 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:12:50:40 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:12:51:02 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:12:51:02 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:12:51:02 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:12:51:02 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:12:51:02 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:12:51:02 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:12:51:02 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:12:51:10 owner OWNER-PC === Setup ended ===
2014/8/28:12:51:45 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:12:51:45 owner OWNER-PC Path_Length: 143
2014/8/28:12:51:45 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:12:51:45 owner OWNER-PC Launch
2014/8/28:12:51:45 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:12:51:45 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI17E5.tmp
2014/8/28:12:51:46 owner OWNER-PC === Setup ended ===
2014/8/28:12:51:45 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:12:51:46 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:12:51:51 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:12:51:51 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:12:51:51 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:12:52:06 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:12:52:07 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:12:52:07 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:12:52:14 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:12:52:14 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:12:52:14 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:12:52:40 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:12:52:40 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:12:52:40 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:12:53:08 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:12:53:09 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:12:53:09 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:12:53:09 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:12:53:09 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:12:53:09 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:12:53:09 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:12:53:14 owner OWNER-PC === Setup ended ===
2014/8/28:13:29:23 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:13:29:23 owner OWNER-PC Path_Length: 143
2014/8/28:13:29:23 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:13:29:23 owner OWNER-PC Launch
2014/8/28:13:29:23 owner OWNER-PC CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /skipPI /SN 900-37024729 /PK 657G1 /akamai
2014/8/28:13:29:23 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI4FB5.tmp
2014/8/28:13:29:34 owner OWNER-PC === Setup ended ===
2014/8/28:13:29:24 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:13:29:24 owner OWNER-PC Path_Length: 143
2014/8/28:13:29:24 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI4FB5.tmp
2014/8/28:13:29:24 owner OWNER-PC Launch
2014/8/28:13:29:25 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:13:29:28 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:13:29:35 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:13:29:38 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:13:29:38 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:13:29:41 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:13:29:41 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:13:29:41 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:13:30:00 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:13:30:00 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:13:30:00 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:13:30:19 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:13:30:20 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:13:30:20 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:13:30:49 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:13:30:50 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:13:30:50 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:13:30:50 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:13:30:50 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:13:30:50 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:13:30:51 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:13:30:59 owner OWNER-PC === Setup ended ===
2014/8/28:13:33:20 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:13:33:20 owner OWNER-PC Path_Length: 143
2014/8/28:13:33:20 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:13:33:20 owner OWNER-PC Launch
2014/8/28:13:33:20 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:13:33:20 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIEB87.tmp
2014/8/28:13:33:21 owner OWNER-PC === Setup ended ===
2014/8/28:13:33:20 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:13:33:21 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:13:33:24 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:13:33:24 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:13:33:24 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:13:33:29 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:13:33:29 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:13:33:29 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:13:33:38 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:13:33:38 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:13:33:38 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:13:33:56 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:13:33:56 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:13:33:56 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:13:34:19 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:13:34:19 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:13:34:19 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:13:34:19 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:13:34:20 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:13:34:20 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:13:34:20 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:13:34:25 owner OWNER-PC === Setup ended ===
2014/8/28:14:13:54 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:14:13:54 owner OWNER-PC Path_Length: 143
2014/8/28:14:13:54 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:14:13:54 owner OWNER-PC Launch
2014/8/28:14:13:54 owner OWNER-PC CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /skipPI /SN 900-37024729 /PK 657G1 /akamai
2014/8/28:14:13:54 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI10B3.tmp
2014/8/28:14:13:59 owner OWNER-PC === Setup ended ===
2014/8/28:14:13:55 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:14:13:55 owner OWNER-PC Path_Length: 143
2014/8/28:14:13:55 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI10B3.tmp
2014/8/28:14:13:55 owner OWNER-PC Launch
2014/8/28:14:13:56 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:14:13:56 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:14:14:01 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:14:14:03 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:14:14:03 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:14:14:08 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:14:14:08 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:14:14:08 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:14:14:20 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:14:14:23 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:14:14:31 owner OWNER-PC === Setup ended ===
2014/8/28:14:18:05 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:14:18:05 owner OWNER-PC Path_Length: 143
2014/8/28:14:18:05 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:14:18:05 owner OWNER-PC Launch
2014/8/28:14:18:05 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:14:18:05 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIE502.tmp
2014/8/28:14:18:06 owner OWNER-PC === Setup ended ===
2014/8/28:14:18:06 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:14:18:06 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:14:18:09 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:14:18:10 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:14:18:10 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:14:18:12 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:14:18:13 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:14:18:13 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:14:18:22 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:14:18:22 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:14:18:22 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:14:18:41 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:14:18:41 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:14:18:41 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:14:19:15 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:14:19:15 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:14:19:15 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:14:19:15 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:14:19:15 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:14:19:15 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:14:19:16 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:14:19:40 owner OWNER-PC === Setup ended ===
2014/8/28:14:27:05 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:14:27:05 owner OWNER-PC Path_Length: 143
2014/8/28:14:27:05 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:14:27:05 owner OWNER-PC Launch
2014/8/28:14:27:05 owner OWNER-PC CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /skipPI /SN 900-37024729 /PK 657G1 /akamai
2014/8/28:14:27:05 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI207C.tmp
2014/8/28:14:27:09 owner OWNER-PC === Setup ended ===
2014/8/28:14:27:06 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:14:27:06 owner OWNER-PC Path_Length: 143
2014/8/28:14:27:06 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI207C.tmp
2014/8/28:14:27:06 owner OWNER-PC Launch
2014/8/28:14:27:07 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:14:27:08 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:14:27:12 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:14:27:17 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:14:27:17 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:14:27:20 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:14:27:21 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:14:27:21 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:14:27:29 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:14:27:29 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:14:27:29 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:14:27:47 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:14:27:47 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:14:27:47 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:14:28:11 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:14:28:12 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:14:28:12 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:14:28:12 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:14:28:12 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:14:28:12 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:14:28:13 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:14:30:07 owner OWNER-PC === Setup ended ===
2014/8/28:16:46:15 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:16:46:15 owner OWNER-PC Path_Length: 143
2014/8/28:16:46:15 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:16:46:15 owner OWNER-PC Launch
2014/8/28:16:46:15 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:16:46:15 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI8A29.tmp
2014/8/28:16:46:18 owner OWNER-PC === Setup ended ===
2014/8/28:16:46:16 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:16:46:16 owner OWNER-PC Path_Length: 143
2014/8/28:16:46:16 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI8A29.tmp
2014/8/28:16:46:16 owner OWNER-PC Launch
2014/8/28:16:46:18 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:16:46:18 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:16:46:22 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:16:46:22 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:16:46:22 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:16:46:26 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:16:46:27 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:16:46:27 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:16:46:38 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:16:46:38 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:16:46:38 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:16:47:04 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:16:47:04 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:16:47:04 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:16:47:49 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:16:47:50 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:16:47:50 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:16:47:50 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:16:47:50 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:16:47:50 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:16:51:42 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:16:51:42 owner OWNER-PC Path_Length: 143
2014/8/28:16:51:42 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:16:51:42 owner OWNER-PC Launch
2014/8/28:16:51:42 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:16:51:42 owner OWNER-PC Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/8/28:16:51:51 owner OWNER-PC Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/8/28:16:51:52 owner OWNER-PC Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/8/28:16:51:53 owner OWNER-PC === Setup ended ===
2014/8/28:16:47:51 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:16:52:12 owner OWNER-PC === Setup ended ===
2014/8/28:16:54:14 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:16:54:14 owner OWNER-PC Path_Length: 143
2014/8/28:16:54:14 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:16:54:14 owner OWNER-PC Launch
2014/8/28:16:54:14 owner OWNER-PC CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /skipPI /SN 900-37024729 /PK 657G1 /akamai
2014/8/28:16:54:14 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIDB93.tmp
2014/8/28:16:54:19 owner OWNER-PC === Setup ended ===
2014/8/28:16:54:15 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:16:54:15 owner OWNER-PC Path_Length: 143
2014/8/28:16:54:15 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIDB93.tmp
2014/8/28:16:54:15 owner OWNER-PC Launch
2014/8/28:16:54:16 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:16:54:16 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:16:54:21 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:16:54:29 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:16:54:29 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:16:54:34 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:16:54:34 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:16:54:34 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:16:54:43 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:16:54:43 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:16:54:43 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:16:55:04 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:16:55:04 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:16:55:04 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:16:55:33 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:16:55:34 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:16:55:34 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:16:55:34 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:16:55:34 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:16:55:34 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:16:55:34 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:16:56:44 owner OWNER-PC === Setup ended ===
2014/8/28:17:03:44 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:03:44 owner OWNER-PC Path_Length: 143
2014/8/28:17:03:44 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIE1F5.tmp
2014/8/28:17:03:44 owner OWNER-PC Launch
2014/8/28:17:03:46 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:17:03:56 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:17:03:41 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:03:41 owner OWNER-PC Path_Length: 143
2014/8/28:17:03:41 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:17:03:41 owner OWNER-PC Launch
2014/8/28:17:03:41 owner OWNER-PC CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /skipPI /SN 900-37024729 /PK 657G1 /akamai
2014/8/28:17:03:41 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIE1F5.tmp
2014/8/28:17:04:23 owner OWNER-PC === Setup ended ===
2014/8/28:17:04:19 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:17:04:23 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:17:04:23 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:17:04:27 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:17:04:27 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:04:27 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:17:05:20 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:17:05:20 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:05:20 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:17:06:19 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:17:06:19 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:17:06:19 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:17:06:53 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:17:06:54 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:17:06:54 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:17:06:55 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:17:06:55 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:17:06:55 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:17:06:59 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:17:07:21 owner OWNER-PC === Setup ended ===
2014/8/28:17:26:18 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:26:18 owner OWNER-PC Path_Length: 143
2014/8/28:17:26:18 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:17:26:18 owner OWNER-PC Launch
2014/8/28:17:26:18 owner OWNER-PC CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /skipPI /SN 900-37024729 /PK 657G1 /akamai
2014/8/28:17:26:18 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI9701.tmp
2014/8/28:17:26:23 owner OWNER-PC === Setup ended ===
2014/8/28:17:26:20 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:26:20 owner OWNER-PC Path_Length: 143
2014/8/28:17:26:20 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI9701.tmp
2014/8/28:17:26:20 owner OWNER-PC Launch
2014/8/28:17:26:21 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:17:26:21 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:17:26:26 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:17:26:29 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:17:26:29 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:17:26:31 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:17:26:32 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:26:32 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:17:26:40 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:17:26:40 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:26:40 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:17:27:00 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:17:27:00 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:17:27:00 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:17:27:23 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:17:27:23 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:17:27:23 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:17:27:23 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:17:27:23 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:17:27:23 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:17:27:24 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:17:27:31 owner OWNER-PC === Setup ended ===
2014/8/28:17:48:42 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:48:42 owner OWNER-PC Path_Length: 143
2014/8/28:17:48:42 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:17:48:42 owner OWNER-PC Launch
2014/8/28:17:48:42 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:17:48:42 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI8C28.tmp
2014/8/28:17:48:46 owner OWNER-PC === Setup ended ===
2014/8/28:17:48:43 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:48:43 owner OWNER-PC Path_Length: 143
2014/8/28:17:48:43 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI8C28.tmp
2014/8/28:17:48:43 owner OWNER-PC Launch
2014/8/28:17:48:44 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:17:48:46 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:17:49:08 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:17:49:08 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:17:49:09 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:17:49:12 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:17:49:12 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:49:12 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:17:49:26 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:17:49:26 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:49:26 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:17:49:47 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:17:49:47 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:17:49:47 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:17:50:19 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:17:50:20 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:17:50:20 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:17:50:20 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:17:50:20 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:17:50:20 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:17:50:20 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:17:51:25 owner OWNER-PC === Setup ended ===
2014/8/28:17:52:29 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:52:29 owner OWNER-PC Path_Length: 143
2014/8/28:17:52:29 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:17:52:29 owner OWNER-PC Launch
2014/8/28:17:52:29 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:17:52:29 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI222.tmp
2014/8/28:17:52:30 owner OWNER-PC === Setup ended ===
2014/8/28:17:52:29 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:17:52:30 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:17:52:54 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:17:52:54 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:17:52:54 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:17:52:56 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:17:52:56 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:52:56 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:17:53:06 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:17:53:06 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:53:06 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:17:53:33 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:17:53:33 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:17:53:33 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:17:53:58 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:17:53:59 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:17:53:59 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:17:53:59 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:17:53:59 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:17:53:59 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:17:54:00 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:17:54:09 owner OWNER-PC === Setup ended ===
2014/8/28:17:54:41 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:54:41 owner OWNER-PC Path_Length: 143
2014/8/28:17:54:41 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:17:54:41 owner OWNER-PC Launch
2014/8/28:17:54:41 owner OWNER-PC CommandLine
2014/8/28:17:54:41 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI666.tmp
2014/8/28:17:54:50 owner OWNER-PC === Setup ended ===
2014/8/28:17:54:42 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:54:42 owner OWNER-PC Path_Length: 143
2014/8/28:17:54:42 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI666.tmp
2014/8/28:17:54:42 owner OWNER-PC Launch
2014/8/28:17:54:51 owner OWNER-PC === Setup ended ===
2014/8/28:17:55:43 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:17:55:43 owner OWNER-PC Path_Length: 143
2014/8/28:17:55:43 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:17:55:43 owner OWNER-PC Launch
2014/8/28:17:55:43 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:17:55:43 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIFA36.tmp
2014/8/28:17:55:44 owner OWNER-PC === Setup ended ===
2014/8/28:17:55:44 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:17:55:44 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:17:56:33 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:17:56:33 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:17:56:33 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:17:56:38 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:17:56:39 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:56:39 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:17:56:44 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:17:56:44 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:17:56:44 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:17:57:05 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:17:57:05 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:17:57:05 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:17:57:28 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:17:57:29 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:17:57:29 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:17:57:29 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:17:57:29 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:17:57:29 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:17:57:30 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:17:57:49 owner OWNER-PC === Setup ended ===
2014/8/28:18:53:11 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:18:53:11 owner OWNER-PC Path_Length: 143
2014/8/28:18:53:11 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:18:53:11 owner OWNER-PC Launch
2014/8/28:18:53:11 owner OWNER-PC CommandLine
2014/8/28:18:53:11 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI96E3.tmp
2014/8/28:18:53:18 owner OWNER-PC === Setup ended ===
2014/8/28:18:53:13 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:18:53:13 owner OWNER-PC Path_Length: 143
2014/8/28:18:53:13 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI96E3.tmp
2014/8/28:18:53:13 owner OWNER-PC Launch
2014/8/28:18:53:19 owner OWNER-PC === Setup ended ===
2014/8/28:20:25:14 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:20:25:14 owner OWNER-PC Path_Length: 143
2014/8/28:20:25:14 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/28:20:25:14 owner OWNER-PC Launch
2014/8/28:20:25:14 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/28:20:25:14 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIDC0E.tmp
2014/8/28:20:25:20 owner OWNER-PC === Setup ended ===
2014/8/28:20:25:15 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/28:20:25:15 owner OWNER-PC Path_Length: 143
2014/8/28:20:25:15 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AIDC0E.tmp
2014/8/28:20:25:15 owner OWNER-PC Launch
2014/8/28:20:25:16 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/28:20:25:17 owner OWNER-PC PageOpen LaunchDialog
2014/8/28:20:25:21 owner OWNER-PC PageOpen LicenseDialog
2014/8/28:20:25:21 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/28:20:25:21 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/28:20:25:24 owner OWNER-PC PageOpen FullProgressDialog
2014/8/28:20:25:24 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:20:25:24 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/28:20:26:04 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/28:20:26:04 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/28:20:26:04 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/28:20:26:31 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/28:20:26:31 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/28:20:26:31 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/28:20:26:58 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/28:20:26:58 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/28:20:26:58 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/28:20:26:58 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/28:20:26:59 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/28:20:26:59 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/28:20:27:00 owner OWNER-PC PageOpen InstallCompleteDialog
2014/8/28:20:27:06 owner OWNER-PC === Setup ended ===
2014/8/29:07:54:29 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/29:07:54:29 owner OWNER-PC Path_Length: 143
2014/8/29:07:54:29 owner OWNER-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/8/29:07:54:29 owner OWNER-PC Launch
2014/8/29:07:54:29 owner OWNER-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-37024729 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/29:07:54:29 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI556F.tmp
2014/8/29:07:54:32 owner OWNER-PC === Setup ended ===
2014/8/29:07:54:30 owner OWNER-PC === Setup started on OWNER-PC by owner ===
2014/8/29:07:54:30 owner OWNER-PC Path_Length: 143
2014/8/29:07:54:30 owner OWNER-PC Current Directory C:\Users\owner\AppData\Local\Temp\_AI556F.tmp
2014/8/29:07:54:30 owner OWNER-PC Launch
2014/8/29:07:54:31 owner OWNER-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/8/29:07:54:32 owner OWNER-PC PageOpen LaunchDialog
2014/8/29:07:54:36 owner OWNER-PC PageOpen LicenseDialog
2014/8/29:07:54:36 owner OWNER-PC PageOpen ProductInfoDialog
2014/8/29:07:54:36 owner OWNER-PC PageOpen ProductSelectionDialog2
2014/8/29:07:54:40 owner OWNER-PC PageOpen FullProgressDialog
2014/8/29:07:54:40 owner OWNER-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/29:07:54:40 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/29:07:54:54 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/29:07:54:54 owner OWNER-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/8/29:07:54:54 owner OWNER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/29:07:55:25 owner OWNER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/29:07:55:26 owner OWNER-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/8/29:07:55:26 owner OWNER-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/29:07:56:19 owner OWNER-PC Install DirectX® Runtime Succeeded
2014/8/29:07:56:20 owner OWNER-PC Download Error Connection has expired. Please reconnect to site. MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/8/29:07:56:20 owner OWNER-PC Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/8/29:07:56:20 owner OWNER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/29:07:56:20 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/29:07:56:20 owner OWNER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Hi @Anonymous,
Apologies for the late reply! Please see @TravisNave's solution on how to resolve 1600 errors. I hope this helps! If you need further help please be sure to let us know.
thanks!
