Installation & Licensing
Trial Maya 2011 on mac OS X license error?
10 REPLIES 10
Message 1 of 11
389 Views, 10 Replies
from what i read 2011 is a very promising release and i downloaded yesterday to check it out. However i get a license error at launch time..
I'm quite sure that i use 000-000000000 as serial and product code and i don't know what seems to be the problem..
Moreover, when i tried to reinstall it i had some messages like "...failed on exit"...
Thanks in advance,
mike
edit: License file override: environment variable MAYA_ALT_EN is not set
10 REPLIES 10
Message 2 of 11
i have this problem too
Message 3 of 11
i have it too, and maya just wont start.
why??
never mind, maya works perfect now, just restart de Mac. :)
Message 4 of 11
By the way, i have 10.6.3 SL and it persists after restart or reinstall. I have also Little Sntch app running, although it gives no errors or warnings...
Message 5 of 11
Anyone?
Message 6 of 11
the problem is still there
Message 7 of 11
I'm getting this same error on the pc as well. Running vista trying to install the 64 bit version. I did 2 installs and uninstalls. Still no luck. Any updates on this would be great really wanted to test out the new maya.
Message 8 of 11
Ok i give up...
after downloading two times the DMG trial and many in/un - istallations the problem perists. I don't know what might be the problem but i can't find it , so i'll wait for a hotfix or smt...
Message 9 of 11
I have the same problem. Temprorary solution is to set to english language on your system. I have Polish language and when i change to English Maya launched.
Message 10 of 11
Thank you friend!!!
Message 11 of 11
I also have the same problem on a Mac. My language is definitely set to English, since that's the only language I use. Is there a place to report bugs to Autodesk? This seems like a serious problem that lots of people are having.
Administrator Productivity
