Hi @hillpony and welcome to the Autodesk Community!
We're happy to help but need more information from you:
What operating system are you running?
What did the error message say while you were downloading?
Have you tried clearing your cookies and cache?
Did you by chance try a different download method?
Also, you can download any version of Maya that you like. It all depends on what you need. Thanks very much for your help in resolving this issue, we look forward to hearing from you!
Hi Jessica,
My old computer was running vista, and the new one is windows 8. I don't remember the error message, but I just got home from work and am going to try it again. I have not tried clearing the cookies and cache, but I will. I also was using the same download process as I did the first time. Also if I download a newer version of Maya, will my saves from the 2013 version open and work properly in the newer versions? Thanks for you help.
Shaun
Hi Shaun,
If you haven't already started, take these precautions before your next download attempt:
The older drawings should open in the newer version of Maya as the two versions are close in release dates, however it's always possible that some could be lost in the transition.
If the error persists after that please reply with further details. Thank you!
Hi Shaun,
If you run into any errors it would be great to get a screenshot of that, or any other messaging that you think may be related to a failed download. But definitely let me know how it goes! Good luck!
Hey Jessica,
Got home and everything was downloaded. I'm up and running and I've tried all my saved projects and they all work as well. Thanks so much for you help!!
Shaun
