Downloaded SP4
Installed
MR not working (plugin refuse to load)
Read online that previous MR versions has to be uninstalled
Uninstalled all MR components
Download MR Satellite
Install MR satellite, restart
MR doesnt even show up under plugins - and there isnt even a plugin-file around *
Download MR Standalone and try that
...and it asks for a bloody key!
Where is the -normal- Mental Ray download that actually works???
EDIT:
* - Not a single mll inside c:\Program Files\Autodesk\mrsat3.12.1-maya2015\
Solved by martin. Go to Solution.
Never mind. I see that it was just hidden in plain sight:
mental_ray_for_Autodesk_Maya_2015_SP4_Win.msp
...under Autodesk Maya 2015 Service Pack 4.
But I can´t install it since I get an error:
"The upgrade patch cannot be installed by the Windows Installer service because the program to be upgraded may be missing, or the upgrade patch may update a different version of the program"
Yesterday I also found out that that mental ray for me is not working. Glad I'm not the only one though, I've been trying to fix it all day and even on the mental ray patch for sp4 I'm getting the same error message. So far no luck on trying 😞 been bothering me like heck
Finally got it working.
This is the correct order of installation:
Maya 2015 > Extension 1 > Service Pack 4 > Mental Ray update
The correct Mental Ray download on:
http://knowledge.autodesk.com/support/maya/downloads/caas/downloads/content/autodesk-maya-2015-servi...
...is the file called mental_ray_for_Autodesk_Maya_2015_SP4_Win.msp (msp - 36.30Mb)
But if you, like me, happend to uninstall Mental Ray completely prior to trying to do the update, then you need to run the Maya software installation file again and install Mental Ray (before running the patch above).
Hope that helps.
Hey Martin, I'm getting this error too:
But I downloaded the correct file?
Go into the Control Panel and check the list of installed programs to make sure that you have Mental Ray installed.
I did the mistake of uninstalling it prior to trying to applying the patch - which gave me that same error message.
If it´s missing you will have to download the Maya installer again and install Mental Ray before you apply the patch.
