I tried installing Maya 2015 and mental ray.
Nothign installed and I got a "Installation Incomplete. Some Products failed to install" message.
This is what i see now.
The logs are a s follows
Maya:
2014/9/11:19:10:36 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:10:36 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:10:36 Patrick NCC-1701-J Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/11:19:10:36 Patrick NCC-1701-J Launch
2014/9/11:19:10:36 Patrick NCC-1701-J CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-24468232 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/11:19:10:36 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI7F76.tmp
2014/9/11:19:12:04 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:10:37 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:10:37 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:10:37 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI7F76.tmp
2014/9/11:19:10:37 Patrick NCC-1701-J Launch
2014/9/11:19:11:23 Patrick NCC-1701-J Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/11:19:12:04 Patrick NCC-1701-J Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/11:19:12:04 Patrick NCC-1701-J PageOpen LaunchDialog
2014/9/11:19:17:29 Patrick NCC-1701-J PageOpen LicenseDialog
2014/9/11:19:17:29 Patrick NCC-1701-J PageOpen ProductInfoDialog
2014/9/11:19:17:29 Patrick NCC-1701-J PageOpen ProductSelectionDialog2
2014/9/11:19:18:14 Patrick NCC-1701-J PageOpen FullProgressDialog
2014/9/11:19:18:15 Patrick NCC-1701-J Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/11:19:18:15 Patrick NCC-1701-J Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/11:19:18:15 Patrick NCC-1701-J PageOpen InstallCompleteDialog
2014/9/11:19:18:25 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:22:14 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:22:14 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:22:14 Patrick NCC-1701-J Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/11:19:22:14 Patrick NCC-1701-J Launch
2014/9/11:19:22:14 Patrick NCC-1701-J CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-24468232 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/11:19:22:14 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI2611.tmp
2014/9/11:19:22:17 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:22:17 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:22:17 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:22:17 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI2611.tmp
2014/9/11:19:22:17 Patrick NCC-1701-J Launch
2014/9/11:19:22:17 Patrick NCC-1701-J Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/11:19:22:17 Patrick NCC-1701-J PageOpen LaunchDialog
2014/9/11:19:22:25 Patrick NCC-1701-J PageOpen LicenseDialog
2014/9/11:19:22:25 Patrick NCC-1701-J PageOpen ProductInfoDialog
2014/9/11:19:22:25 Patrick NCC-1701-J PageOpen ProductSelectionDialog2
2014/9/11:19:22:33 Patrick NCC-1701-J PageOpen FullProgressDialog
2014/9/11:19:22:34 Patrick NCC-1701-J Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/11:19:22:34 Patrick NCC-1701-J Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/11:19:22:34 Patrick NCC-1701-J PageOpen InstallCompleteDialog
2014/9/11:19:22:44 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:29:20 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:29:20 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:29:20 Patrick NCC-1701-J Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/11:19:29:20 Patrick NCC-1701-J Launch
2014/9/11:19:29:20 Patrick NCC-1701-J CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-24468232 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/11:19:29:20 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AIA869.tmp
2014/9/11:19:29:28 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:29:22 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:29:22 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:29:22 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AIA869.tmp
2014/9/11:19:29:22 Patrick NCC-1701-J Launch
2014/9/11:19:29:23 Patrick NCC-1701-J Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/11:19:29:23 Patrick NCC-1701-J Connection has expired. Please reconnect to site.2014/9/11:19:29:29 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:29:50 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:29:50 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:29:50 Patrick NCC-1701-J Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/11:19:29:50 Patrick NCC-1701-J Launch
2014/9/11:19:29:50 Patrick NCC-1701-J CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-24468232 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/11:19:29:50 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI1A2F.tmp
2014/9/11:19:29:54 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:29:51 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:29:51 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:29:51 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI1A2F.tmp
2014/9/11:19:29:51 Patrick NCC-1701-J Launch
2014/9/11:19:29:52 Patrick NCC-1701-J Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/11:19:29:52 Patrick NCC-1701-J Connection has expired. Please reconnect to site.2014/9/11:19:29:55 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:31:49 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:31:49 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:31:49 Patrick NCC-1701-J Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/11:19:31:49 Patrick NCC-1701-J Launch
2014/9/11:19:31:49 Patrick NCC-1701-J CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-24468232 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/11:19:31:49 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AIEDD2.tmp
2014/9/11:19:31:52 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:31:51 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:31:51 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:31:51 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AIEDD2.tmp
2014/9/11:19:31:51 Patrick NCC-1701-J Launch
2014/9/11:19:31:51 Patrick NCC-1701-J Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/11:19:31:51 Patrick NCC-1701-J PageOpen LaunchDialog
2014/9/11:19:31:59 Patrick NCC-1701-J PageOpen LicenseDialog
2014/9/11:19:31:59 Patrick NCC-1701-J PageOpen ProductInfoDialog
2014/9/11:19:31:59 Patrick NCC-1701-J PageOpen ProductSelectionDialog2
2014/9/11:19:32:17 Patrick NCC-1701-J PageOpen FullProgressDialog
2014/9/11:19:32:19 Patrick NCC-1701-J Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/11:19:32:19 Patrick NCC-1701-J Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/9/11:19:32:19 Patrick NCC-1701-J PageOpen InstallCompleteDialog
2014/9/11:19:32:43 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:34:46 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:34:46 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:34:46 Patrick NCC-1701-J Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/9/11:19:34:46 Patrick NCC-1701-J Launch
2014/9/11:19:34:46 Patrick NCC-1701-J CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-24468232 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/11:19:34:46 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI9EC9.tmp
2014/9/11:19:34:49 Patrick NCC-1701-J === Setup ended ===
2014/9/11:19:34:47 Patrick NCC-1701-J === Setup started on NCC-1701-J by Patrick ===
2014/9/11:19:34:47 Patrick NCC-1701-J Path_Length: 143
2014/9/11:19:34:47 Patrick NCC-1701-J Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI9EC9.tmp
2014/9/11:19:34:47 Patrick NCC-1701-J Launch
2014/9/11:19:34:47 Patrick NCC-1701-J Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/9/11:19:34:47 Patrick NCC-1701-J PageOpen LaunchDialog
2014/9/11:19:34:55 Patrick NCC-1701-J PageOpen LicenseDialog
2014/9/11:19:34:55 Patrick NCC-1701-J PageOpen ProductInfoDialog
2014/9/11:19:34:55 Patrick NCC-1701-J PageOpen ProductSelectionDialog2
2014/9/11:19:35:04 Patrick NCC-1701-J PageOpen FullProgressDialog
2014/9/11:19:35:05 Patrick NCC-1701-J Download Error Connection has expired. Please reconnect to site. VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/9/11:19:35:05 Patrick NCC-1701-J Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
Direct connect:
I am using avast free antivirus and Windows firewall gave me trouble about Akami.
Please help.
