Installation & Licensing
Problem to install 3ds Max 2013
4 REPLIES 4
1854 Views, 4 Replies
Hi, my problem is this
After running the installer shows me this message
Some products
This is the log file
2013/5/26:00:40:05 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/5/26:00:40:05 Beto PTTJ2004 Launch
2013/5/26:00:42:04 Beto PTTJ2004 === Setup ended ===
2013/5/26:00:40:32 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/5/26:00:40:32 Beto PTTJ2004 Launch
2013/5/26:00:40:58 Beto PTTJ2004 PageOpen LaunchDialog
2013/5/26:00:48:26 Beto PTTJ2004 === Setup ended ===
2013/5/26:00:48:47 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/5/26:00:48:47 Beto PTTJ2004 Launch
2013/5/26:00:48:47 Beto PTTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:00:50:29 Beto PTTJ2004 === Setup ended ===
2013/5/26:01:02:56 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/5/26:01:02:56 Beto PTTJ2004 Launch
2013/5/26:01:02:56 Beto PTTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:01:03:19 Beto PTTJ2004 === Setup ended ===
2013/5/26:01:04:10 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/5/26:01:04:10 Beto PTTJ2004 Launch
2013/5/26:01:04:29 Beto PTTJ2004 === Setup ended ===
2013/5/26:01:06:51 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/5/26:01:06:51 Beto PTTJ2004 Launch
2013/5/26:01:06:51 Beto PTTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:01:06:53 Beto PTTJ2004 === Setup ended ===
2013/5/26:01:07:11 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/5/26:01:07:11 Beto PTTJ2004 Launch
2013/5/26:01:07:19 Beto PTTJ2004 === Setup ended ===
2013/7/31:18:33:03 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/7/31:18:33:03 Beto PTTJ2004 Launch
2013/7/31:18:33:20 Beto PTTJ2004 === Setup ended ===
2013/7/31:18:33:09 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/7/31:18:33:09 Beto PTTJ2004 Launch
2013/7/31:18:33:20 Beto PTTJ2004 PageOpen LaunchDialog
2013/7/31:18:33:35 Beto PTTJ2004 PageOpen LicenseDialog
2013/7/31:18:33:38 Beto PTTJ2004 PageOpen ProductInfoDialog
2013/7/31:18:34:44 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/7/31:18:34:55 Beto PTTJ2004 PageOpen FullProgressDialog
2013/7/31:18:34:55 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent
2013/7/31:18:39:39 Beto PTTJ2004 Install DirectX® Runtime Succeeded
2013/7/31:18:39:39 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:18:39:44 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/7/31:18:39:45 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/7/31:18:39:48 Beto PTTJ2004 PageOpen InstallCompleteDialog
2013/7/31:19:03:36 Beto PTTJ2004 === Setup ended ===
2013/7/31:19:10:17 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/7/31:19:10:17 Beto PTTJ2004 Launch
2013/7/31:19:10:51 Beto PTTJ2004 === Setup ended ===
2013/7/31:19:10:34 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/7/31:19:10:34 Beto PTTJ2004 Launch
2013/7/31:19:10:52 Beto PTTJ2004 PageOpen LaunchDialog
2013/7/31:19:12:43 Beto PTTJ2004 PageOpen LicenseDialog
2013/7/31:19:12:50 Beto PTTJ2004 PageOpen ProductInfoDialog
2013/7/31:19:13:33 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/7/31:19:13:52 Beto PTTJ2004 PageOpen FullProgressDialog
2013/7/31:19:13:52 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent
2013/7/31:19:20:53 Beto PTTJ2004 Install DirectX® Runtime Succeeded
2013/7/31:19:20:53 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:19:20:56 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/7/31:19:20:58 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/7/31:19:20:59 Beto PTTJ2004 PageOpen InstallCompleteDialog
2013/7/31:19:41:04 Beto PTTJ2004 === Setup ended ===
2013/8/1:13:49:15 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:13:49:15 Beto PTTJ2004 Launch
2013/8/1:13:49:27 Beto PTTJ2004 === Setup ended ===
2013/8/1:13:49:19 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:13:49:19 Beto PTTJ2004 Launch
2013/8/1:13:49:28 Beto PTTJ2004 PageOpen LaunchDialog
2013/8/1:13:49:41 Beto PTTJ2004 PageOpen LicenseDialog
2013/8/1:13:50:06 Beto PTTJ2004 PageOpen ProductInfoDialog
2013/8/1:13:50:53 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/8/1:13:51:02 Beto PTTJ2004 PageOpen FullProgressDialog
2013/8/1:13:51:04 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/8/1:13:51:38 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/8/1:13:51:38 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/8/1:13:51:49 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/8/1:13:51:49 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/1:13:56:16 Beto PTTJ2004 Install DirectX® Runtime Succeeded
2013/8/1:13:56:16 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/1:13:56:17 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/8/1:13:56:17 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/1:13:56:17 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/1:13:56:17 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/1:13:56:19 Beto PTTJ2004 PageOpen InstallCompleteDialog
2013/8/1:14:28:43 Beto PTTJ2004 === Setup ended ===
2013/8/1:15:20:32 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:15:20:32 Beto PTTJ2004 Launch
2013/8/1:15:20:48 Beto PTTJ2004 === Setup ended ===
2013/8/1:15:20:39 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:15:20:39 Beto PTTJ2004 Launch
2013/8/1:15:20:48 Beto PTTJ2004 PageOpen LaunchDialog
2013/8/1:15:20:52 Beto PTTJ2004 PageOpen LicenseDialog
2013/8/1:15:21:06 Beto PTTJ2004 PageOpen ProductInfoDialog
2013/8/1:15:21:37 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/8/1:15:21:44 Beto PTTJ2004 PageOpen FullProgressDialog
2013/8/1:15:21:44 Beto PTTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/8/1:15:21:51 Beto PTTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/8/1:15:21:51 Beto PTTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/8/1:15:22:20 Beto PTTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/8/1:15:22:20 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/1:15:28:31 Beto PTTJ2004 Install DirectX® Runtime Succeeded
2013/8/1:15:28:31 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/1:15:28:31 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/8/1:15:28:32 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/1:15:28:32 Beto PTTJ2004 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/1:15:28:32 Beto PTTJ2004 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/1:15:28:35 Beto PTTJ2004 PageOpen InstallCompleteDialog
2013/8/1:15:30:35 Beto PTTJ2004 === Setup ended ===
2013/8/1:15:47:07 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:15:47:07 Beto PTTJ2004 Launch
2013/8/1:15:47:15 Beto PTTJ2004 === Setup ended ===
2013/8/1:15:47:10 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:15:47:10 Beto PTTJ2004 Launch
2013/8/1:15:47:15 Beto PTTJ2004 PageOpen LaunchDialog
2013/8/1:15:47:19 Beto PTTJ2004 PageOpen LicenseDialog
2013/8/1:15:47:29 Beto PTTJ2004 PageOpen ProductInfoDialog
2013/8/1:15:48:33 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/8/1:15:48:45 Beto PTTJ2004 PageOpen FullProgressDialog
2013/8/1:15:48:45 Beto PTTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/8/1:15:49:11 Beto PTTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/8/1:15:49:11 Beto PTTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/8/1:15:49:39 Beto PTTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/8/1:15:49:39 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/1:15:57:49 Beto PTTJ2004 Install DirectX® Runtime Succeeded
2013/8/1:15:57:50 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/1:15:57:50 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/8/1:15:57:50 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/1:15:57:50 Beto PTTJ2004 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/1:15:57:50 Beto PTTJ2004 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/1:15:58:09 Beto PTTJ2004 PageOpen InstallCompleteDialog
2013/8/1:15:58:51 Beto PTTJ2004 === Setup ended ===
2013/8/1:16:36:24 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:16:36:24 Beto PTTJ2004 Launch
2013/8/1:16:36:37 Beto PTTJ2004 === Setup ended ===
2013/8/1:16:36:51 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:16:36:51 Beto PTTJ2004 Launch
2013/8/1:16:36:51 Beto PTTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/8/1:16:36:52 Beto PTTJ2004 === Setup ended ===
2013/8/1:16:36:33 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:16:36:33 Beto PTTJ2004 Launch
2013/8/1:16:36:37 Beto PTTJ2004 PageOpen LaunchDialog
2013/8/1:16:36:42 Beto PTTJ2004 PageOpen LicenseDialog
2013/8/1:16:36:45 Beto PTTJ2004 PageOpen LaunchDialog
2013/8/1:16:38:29 Beto PTTJ2004 PageOpen LicenseDialog
2013/8/1:16:38:29 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/8/1:16:38:43 Beto PTTJ2004 PageOpen FullProgressDialog
2013/8/1:16:38:46 Beto PTTJ2004 Installing Autodesk® 3ds Max 2013 SDK: TRANSFORMS="C:\Users\Beto\AppData\Local\Temp\_AIBABA.tmp\x86\Tools\MAXSDK\SDK_3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/1:16:38:46 Beto PTTJ2004 Install Autodesk® 3ds Max 2013 SDK Failed Failure is ignored, Result=2
2013/8/1:16:38:46 Beto PTTJ2004 Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/1:16:38:46 Beto PTTJ2004 Install Network License Manager Failed Failure is ignored, Result=2
2013/8/1:16:38:46 Beto PTTJ2004 PageOpen InstallCompleteDialog
2013/8/1:16:47:04 Beto PTTJ2004 === Setup ended ===
2013/8/1:17:03:52 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:17:03:52 Beto PTTJ2004 Launch
2013/8/1:17:04:11 Beto PTTJ2004 === Setup ended ===
2013/8/1:17:04:06 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:17:04:06 Beto PTTJ2004 Launch
2013/8/1:17:04:11 Beto PTTJ2004 PageOpen LaunchDialog
2013/8/1:17:23:06 Beto PTTJ2004 PageOpen LicenseDialog
2013/8/1:17:23:24 Beto PTTJ2004 PageOpen ProductInfoDialog
2013/8/1:17:24:10 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/8/1:17:24:13 Beto PTTJ2004 PageOpen FullProgressDialog
2013/8/1:17:24:14 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/8/1:17:24:40 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/8/1:17:24:40 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/8/1:17:24:53 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/8/1:17:24:53 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/1:17:27:59 Beto PTTJ2004 Install DirectX® Runtime Succeeded
2013/8/1:17:27:59 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/1:17:28:00 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/8/1:17:28:01 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/1:17:28:01 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/1:17:28:01 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/1:17:28:04 Beto PTTJ2004 PageOpen InstallCompleteDialog
2013/8/1:17:47:22 Beto PTTJ2004 === Setup ended ===
2013/8/1:18:25:03 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:18:25:03 Beto PTTJ2004 Launch
2013/8/1:18:25:21 Beto PTTJ2004 === Setup ended ===
2013/8/1:18:25:09 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:18:25:09 Beto PTTJ2004 Launch
2013/8/1:18:25:21 Beto PTTJ2004 PageOpen LaunchDialog
2013/8/1:18:25:23 Beto PTTJ2004 PageOpen LicenseDialog
2013/8/1:18:25:32 Beto PTTJ2004 PageOpen ProductInfoDialog
2013/8/1:18:26:17 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/8/1:18:27:11 Beto PTTJ2004 PageOpen FullProgressDialog
2013/8/1:18:27:11 Beto PTTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/8/1:18:28:26 Beto PTTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/8/1:18:28:26 Beto PTTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/8/1:18:28:43 Beto PTTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/8/1:18:28:43 Beto PTTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/8/1:18:28:52 Beto PTTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/8/1:18:28:52 Beto PTTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/8/1:18:29:01 Beto PTTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/8/1:18:29:01 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/1:18:34:54 Beto PTTJ2004 Install DirectX® Runtime Succeeded
2013/8/1:18:34:54 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/1:18:34:55 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/8/1:18:34:56 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/1:18:34:56 Beto PTTJ2004 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/1:18:34:57 Beto PTTJ2004 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/1:18:34:57 Beto PTTJ2004 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/1:18:34:57 Beto PTTJ2004 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/1:18:35:00 Beto PTTJ2004 PageOpen InstallCompleteDialog
2013/8/1:18:35:57 Beto PTTJ2004 === Setup ended ===
2013/8/1:19:05:34 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:19:05:34 Beto PTTJ2004 Launch
2013/8/1:19:07:58 Beto PTTJ2004 === Setup ended ===
2013/8/1:19:07:51 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto ===
2013/8/1:19:07:51 Beto PTTJ2004 Launch
2013/8/1:19:07:59 Beto PTTJ2004 PageOpen LaunchDialog
2013/8/1:19:08:28 Beto PTTJ2004 PageOpen LicenseDialog
2013/8/1:19:08:35 Beto PTTJ2004 PageOpen ProductInfoDialog
2013/8/1:19:10:05 Beto PTTJ2004 PageOpen ProductSelectionDialog2
2013/8/1:19:10:12 Beto PTTJ2004 PageOpen FullProgressDialog
2013/8/1:19:10:12 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/8/1:19:10:25 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/8/1:19:10:25 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/1:19:14:17 Beto PTTJ2004 Install DirectX® Runtime Succeeded
2013/8/1:19:14:17 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/1:19:14:19 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2
2013/8/1:19:14:20 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/1:19:14:20 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Help me please!
4 REPLIES 4
Steve_Curley
You must be logged in as Administrator to install Max, and you must run it at least once as Administrator before using it in a normal (limited) user account.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Goto 3rd party folder and install all applications and your problem will be fixed. My problem was fixed by that method.
in reply to: Steve_Curley
How do you sign in as an administrator? I can only see student/ faculty/ mentor as options.. Getting so fustrated with this, I literally cannot continue with my course until this gets sorted 😞
Steve_Curley
Just right-click the installer > Run As Administrator. When you run Max (the first time) right-click the shortcut > Compatibilty tab > Run as administrator. OK it then double-click the shortcut as normal.
Max 2016 (SP1/EXT1)
Administrator Productivity
