Everytime I open Maya 2015 on my PC I get this error:
1 error generated.
Error while processing C:\Program Files\Autodesk\Maya2015\plug-ins\bifrost\db\presets\__rootincludeall__.h.
What does this mean? Will it effect the functionality of the program? I do notice that sometimes Maya will crash for no reason, would this be related?
How can I fix this?
More details: I am running Windows 8.1 on my PC. The installation went smoothly and I had my firewall turned off when I installed it like suggested. So I think everything installed properly.
This is a known error that the Autodesk Maya Development are aware of and are investigating to see if this error can be avoided in a future release. That being said, it has been determined that it does not affect the functionality of the software, you can just ignore it.
Thank-you
Karen
Still no fix for this error in the Console?
I get the same on every launch. But Bifrost seems to be working though...
I found that disabling from autoloading bifrostcis.dll in the plugin manager silenced this error.
I wouldn't turn off anything.
I don't know much about Bifrost except me just fooling around with it. I have not noticed it being affected by the error. You said it worked just fine for you? No problems? I'm going to just ignore the error.
was this issue ever solved because i running into the same problem and none my windows will open ethier. heres a link to my screencapture so u see what i mean:
http://forums.autodesk.com/t5/maya-general/bitfrost/td-p/5965351
