Installation & Licensing
Mentalray error - not loading at startup...
1 REPLY 1
344 Views, 1 Reply
After installing an ATI Radeon X800 XT card I tried to use mentalray, it was no longer set to load at startup and when I tried to use it I got this error; does anyone know how to fix this?
// Error: (Mayatomr.Export) : mental ray startup failed with errors //
// Info (Mayatomr): Aborted //
// Error: (mental ray) : /Volumes/Max/Maya application folder/Maya.app/Contents/mentalray/lib/mayahair.so: load failed, //
// Error: (mental ray) : /Volumes/Max/Maya application folder/Maya.app/Contents/mentalray/lib/mi_openexr.so: load failed, //
// Error: (mental ray) : /Volumes/Max/Maya application folder/Maya.app/Contents/mentalray/lib/paint.so: load failed, //
// Error: (mental ray) : /Volumes/Max/Maya application folder/Maya.app/Contents/mentalray/lib/subsurface.so: load failed, //
// Error: (mental ray) : /Volumes/Max/Maya application folder/Maya.app/Contents/mentalray/lib/contour.so: load failed, //
// Error: (mental ray) : /Volumes/Max/Maya application folder/Maya.app/Contents/mentalray/lib/mayabase.so: load failed, //
// Error: (mental ray) : /Volumes/Max/Maya application folder/Maya.app/Contents/mentalray/lib/physics.so: load failed, //
// Error: (mental ray) : /Volumes/Max/Maya application folder/Maya.app/Contents/mentalray/lib/base.so: load failed, //
1 REPLY 1
Hi bro,I think you can do the same thing for maya,but folders and files are different of course 🙂
http://www.youtube.com/watch?v=Yutx0MGNlPg
Administrator Productivity
