Am having trouble installing Autodesk Maya (student registration). We had a working version installed on our Windows 8 computer last year but had to 'reset' the computer due to performance issues and other problems. Now Maya will not install. Have cleared temp folder, installed with local admin rights, turned off UAC off and antivirus but it still fails. Here is the installation log. Any thoughts greatly appreciated.
Antony Mann.
2014/12/2:21:49:31 Antony BIGMUTHA === Setup started on BIGMUTHA by Antony ===
2014/12/2:21:49:31 Antony BIGMUTHA Path_Length: 143
2014/12/2:21:49:31 Antony BIGMUTHA Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2014/12/2:21:49:31 Antony BIGMUTHA Launch
2014/12/2:21:49:31 Antony BIGMUTHA CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe" /SN 900-51519160 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/2:21:49:31 Antony BIGMUTHA Current Directory C:\Users\Antony\AppData\Local\Temp\_AI4D47.tmp
2014/12/2:21:49:34 Antony BIGMUTHA === Setup ended ===
2014/12/2:21:49:32 Antony BIGMUTHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2014/12/2:21:49:34 Antony BIGMUTHA PageOpen LaunchDialog
2014/12/2:21:49:42 Antony BIGMUTHA PageOpen LicenseDialog
2014/12/2:21:49:42 Antony BIGMUTHA PageOpen ProductInfoDialog
2014/12/2:21:49:42 Antony BIGMUTHA PageOpen ProductSelectionDialog2
2014/12/2:21:49:51 Antony BIGMUTHA PageOpen FullProgressDialog
2014/12/2:21:49:51 Antony BIGMUTHA Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2014/12/2:21:49:51 Antony BIGMUTHA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/2:21:50:30 Antony BIGMUTHA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/2:21:50:30 Antony BIGMUTHA Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2014/12/2:21:50:30 Antony BIGMUTHA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/2:21:50:32 Antony BIGMUTHA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/2:21:50:32 Antony BIGMUTHA Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/DIRECTX.t...
2014/12/2:21:50:32 Antony BIGMUTHA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/2:21:50:37 Antony BIGMUTHA Install DirectX® Runtime Succeeded
2014/12/2:21:50:37 Antony BIGMUTHA Download Skipped ADAPPLICATIONMANAGER http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/ADAPPLICA...
2014/12/2:21:50:37 Antony BIGMUTHA Installing Autodesk Application Manager: "C:\Autodesk\WI\Autodesk Maya 2015\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2014/12/2:21:51:42 Antony BIGMUTHA Install Autodesk Application Manager Succeeded
2014/12/2:21:51:42 Antony BIGMUTHA Download Skipped MAYA http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/MAYA_en-U...
2014/12/2:21:51:44 Antony BIGMUTHA Installing Autodesk® Maya® 2015: TRANSFORMS="C:\Users\Antony\AppData\Local\Temp\_AI4D47.tmp\x64\Maya\Maya-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2015" INSTALLDIR="C:\Program Files\Autodesk\Maya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/2:22:02:35 Antony BIGMUTHA Install Autodesk® Maya® 2015 Failed Installation aborted, Result=1603
2014/12/2:22:02:35 Antony BIGMUTHA Rollback Autodesk Application Manager Failed Failure is ignored, Result=1619
2014/12/2:22:02:35 Antony BIGMUTHA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/2:22:02:35 Antony BIGMUTHA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/12/2:22:02:35 Antony BIGMUTHA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/12/2:22:02:36 Antony BIGMUTHA PageOpen InstallCompleteDialog
2014/12/2:22:05:53 Antony BIGMUTHA === Setup ended ===
2014/12/2:22:10:23 Antony BIGMUTHA === Setup started on BIGMUTHA by Antony ===
2014/12/2:22:10:23 Antony BIGMUTHA Path_Length: 143
2014/12/2:22:10:23 Antony BIGMUTHA Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2014/12/2:22:10:23 Antony BIGMUTHA Launch
2014/12/2:22:10:23 Antony BIGMUTHA CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe" /SN 900-51519160 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/2:22:10:23 Antony BIGMUTHA Current Directory C:\Users\Antony\AppData\Local\Temp\_AI66AE.tmp
2014/12/2:22:10:24 Antony BIGMUTHA === Setup ended ===
2014/12/2:22:10:24 Antony BIGMUTHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2014/12/2:22:10:24 Antony BIGMUTHA PageOpen LaunchDialog
2014/12/2:22:10:30 Antony BIGMUTHA PageOpen LicenseDialog
2014/12/2:22:10:30 Antony BIGMUTHA PageOpen ProductInfoDialog
2014/12/2:22:10:30 Antony BIGMUTHA PageOpen ProductSelectionDialog2
2014/12/2:22:10:34 Antony BIGMUTHA PageOpen FullProgressDialog
2014/12/2:22:10:34 Antony BIGMUTHA Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2014/12/2:22:10:34 Antony BIGMUTHA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/2:22:10:37 Antony BIGMUTHA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/2:22:10:37 Antony BIGMUTHA Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2014/12/2:22:10:37 Antony BIGMUTHA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/2:22:10:37 Antony BIGMUTHA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/2:22:10:37 Antony BIGMUTHA Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/DIRECTX.t...
2014/12/2:22:10:37 Antony BIGMUTHA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/2:22:10:39 Antony BIGMUTHA Install DirectX® Runtime Succeeded
2014/12/2:22:10:39 Antony BIGMUTHA Download Skipped MAYA http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/MAYA_en-U...
2014/12/2:22:10:41 Antony BIGMUTHA Installing Autodesk® Maya® 2015: TRANSFORMS="C:\Users\Antony\AppData\Local\Temp\_AI66AE.tmp\x64\Maya\Maya-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2015" INSTALLDIR="C:\Program Files\Autodesk\Maya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/2:22:18:49 Antony BIGMUTHA Install Autodesk® Maya® 2015 Failed Installation aborted, Result=1603
2014/12/2:22:18:49 Antony BIGMUTHA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/2:22:18:49 Antony BIGMUTHA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/12/2:22:18:49 Antony BIGMUTHA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Have a search for solutions to 1603 and 1619 errors. They are related to dependancies that the installer is keyed to install; in later model computers these dependancies are already installed as newer versions. Since an older version cannot be installed over a newer version, the installer stops.
