I reinstalled my laptop and after that i installed maya 2014 expecting to be able to work with it again just like before i reinstalled my pc (it worked on it before i reinstalled it)
But when opening is get this: ( This is at the launch of maya, Nothing is created yet)
Fatal Error. Attempting to save in C:/Users/Flakes/AppData/Local/Temp/Flakes.20120503.2242.ma
Someone said i had to close my triple buffereing on my nvidia but that didn't work at all.
I tried everything i search for ours on google but no body is having a solution for me.
(This problem was with 2013 aswell)
List of done things:
Solved by warnold1. Go to Solution.
I have exactly the same problem and since I don't see much point in just starting a new thread since this is exactly what I have, I wanted to submit here and hope that some one will be able to help. I am not sure how to get the error text to paste it in here... If anyone could give me a hint of how I do that, I could copy paste it in here since the error can be reproduced easily ( aka just double click maya... ) .
my spec:
Windows 7 x64
Intel i7 3770k
Mobo AsRock Z77 Express 4
Nvidia 560ti
As stated before, I also tried to reinstall both Maya 2013 and Maya 2014. And, this also happend after a clean Windows install despite the fact that I had Maya working before the install...
Any ideas? I really need to get going with a project before school starts so I would really apreciate any kind of help!
thank you!
Hy.. sorry for overlooking that one!
Yes, I've just tried it and it worked!
That is awesome! I'm so happy know I could kiss the screen! 🙂 🙂
Have an awesome day!
For other blind people like me who are not seeing the first thread, here's the link: http://forums.autodesk.com/t5/Installation-Hardware-OS/Maya-crashes-on-startup-Windows-7/m-p/4329287...
Edit: can install the latest driver without worries now? I reverted back to Nvidia 320.18 but the latest is 320.49... Do you think is safe to install the last one? Cheers!
i had same problem....
all i did was go to the NVIA control panel/3D settings/manage 3d settings/programs settings
where it says step 1. "select program to customize" all i did was "add" maya. once i added maya without changing any of the setting i clicked "apply" went to my desktop clicked on MAYA and it opened without a problem.
hope this helps
I'm getting this issue on maya 2017 when trying to create a new project.
Fatal Error. Attempting to save in C:/Users/Soc/AppData/Local/Temp/Soc.20161011.0843.ma
Tried the setting this environment variable but didn't help...
MAYA_DISABLE_CIP=1
I attached the crash log. oops the crash log .dmp is not a valid extension to attach.
Im beginning to think Maya does this on purpose to force users into a subscription
